Rail Pressure At Idle
Old Jan 30, 2009 | 09:30 PM
trx's Avatar
trx
Not sure if I may have a problem or not but it seems my rail pressure has dropped at idle. With the TNT rp set at 3 the past couple weeks I have seen my idle pressure at 7500psi, now recently it idles at 5000psi. Other than that truck runs the same , just curious if this could be an indication of something on its way out, plugged filters or just normal for it to change. Any insight would help.
Thanks
Old Jan 30, 2009 | 09:52 PM
pullin hard's Avatar
mine has always idled at that number ever since having a gauge. that was stock pump, and now the stage 3 pump.stock injectors
Old Jan 30, 2009 | 10:05 PM
SMOKIN-U's Avatar
mine idles at 8000-8200 without tuning but with pump its around 6000
Old Jan 30, 2009 | 10:09 PM
lmills's Avatar
03 and 04 trucks should be around 5400 psi, 04.5 and newers are around 6800
Old Jan 30, 2009 | 10:10 PM
trx's Avatar
trx
Thanks for the input like I said not sure if I have a problem but seeing 2500psi less than before has got me concerned.
Old Jan 30, 2009 | 10:20 PM
Spooler's Avatar
Mine has done the same thing. Last time it changed I unplugged my RP gauge and plugged it back in. Problem solved.
Old Jan 31, 2009 | 12:12 AM
trx's Avatar
trx
Thanks Spooler will give that a try tomorrow, if that does not work I will change my 2 micron filter and go from there.
Old Jan 31, 2009 | 11:57 AM
duallydave's Avatar
is it cold there,when its below 0 here i notice a lower rail pres too,mine idles at 5300 and when its below 0 it idles at 48ish,i was told this is normal for cold temps,could be hapinging wwith urs too,
5.9Excursion
Mar 13, 2008 10:56 AM
sallyman1
Feb 21, 2008 09:04 PM
moparmatt
Oct 29, 2007 07:11 AM
Luvnacumns
16
Apr 18, 2007 10:25 AM
CReed
Apr 17, 2007 06:56 PM
