Quick EZ '03 Question
Old Aug 11, 2004 | 07:33 PM
Gypsyman's Avatar
I've looked at all the threads regarding level 5 and such. Just wanted to make sure that when you are talking about pin placement that you are looking at the pins with the circuit board on the bottom of the box. I'm asking because the new box I recieved has both pins for level 5 but has a pin clipped on the left side of the box, looking at the end with the board towards the bottom. I didn't recieve the instructions and just want to make sure of the pin orientation.
Thanks,
-Richard
Old Aug 11, 2004 | 07:54 PM
Patriot_RAM's Avatar
The side with the "clipped" pin is only for jumper storage. The settings are on the other six pins. Level five is a single jumper on the set of pins nearest the center of the box.
Old Aug 11, 2004 | 08:57 PM
Gypsyman's Avatar
That is looking at the box with the circuit board on the bottom, correct?
Old Aug 12, 2004 | 02:21 AM
mudslinger's Avatar
The pins set at ::: X:: are in refference to the circuit board being on the bottom. Enjoy it makes a huge difference to 4.
Old Aug 12, 2004 | 04:15 AM
Dodgezilla's Avatar
Yes!!!!
Old Aug 12, 2004 | 07:32 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Have their not been lots of folks have problems when running on level 5 or 6??
Old Aug 13, 2004 | 12:25 PM
Dodgezilla's Avatar
Edge just told me that you could possibly make too much fuel rail pressure at level 5 and that's why they don't advertise it. How could you know if your rail pressure is too high? Do they make a guage that goes up to 29,000 psi??
Old Aug 13, 2004 | 01:57 PM
bhoeffner's Avatar
In theory you could use a pressure transducer and appro. gauge that went with the transducer. I have no idea on how you could connect it to the common rail. So there is way to measure the rail pressure it's just sourcing the parts and then coming up with a way to install.
Old Aug 13, 2004 | 04:46 PM
Dodgezilla's Avatar
I'd say that's just a little too complicated for me....
Old Aug 13, 2004 | 05:29 PM
cfm3110's Avatar
I may be an idiot, but I have the EZ and i thought it only went to 4...i havent looked at it since I put it on so I may have forgotten
Old Aug 13, 2004 | 06:00 PM
Dodgezilla's Avatar
cfm, look at mudslingers reply. It tells you how to use the # 5 setting. As was previously stated, Edge doesn't advertise it because of high fuel rail pressures.
HorseHauler
13
Mar 12, 2006 11:48 AM
WSUcougars
Dec 14, 2003 08:52 PM
hellotbone
18
Jun 25, 2003 01:16 PM
dieselcrazy
Feb 15, 2003 06:44 AM
soundbrz
Nov 19, 2002 11:36 PM
