question for TST users
Old Jul 31, 2006 | 07:22 PM
Leon441's Avatar
I was monkeying around and set the power at 7 and te at 2. The truck did not pull anyharder so I turned it up to 7/4 where it still didn't really perform better just smoked more. I then turned it back to 5/2 where I had best results empty. When I started truck again I had a check engine light. I scanned it and it had two "crank sensor out of range errors". I think I snorted it twice at below 2,000 RPM with the 7/4 setting and accelearated to 3,000RPM. If I understand correctly the te works mostly under 2,000 RPM and power over 2,000 RPM. Did the PCM get confused with the settings that far apart or something 7/2? I think TST recommends to stay within a couple of numbers maybe this why.
Old Jul 31, 2006 | 07:26 PM
Luken's Avatar
It doesn't matter what the settings are on. I run mine on 7x2 alot. Do you have a pusher pump yet? The higher settings won't do you much good until you get more fuel going to it. Then the stock turbo cooling it becomes an issue...
Old Jul 31, 2006 | 09:02 PM
Leon441's Avatar
I realize I need a better lift pump. But, that shouldn't have anything to do with a crank sensor out of range code.
Old Jul 31, 2006 | 09:37 PM
CButler610's Avatar
Like Lucas said, I would be VERY careful dialing that much fuel with your level of modifications. Just trying to save you some headache and expense. The P0336 code is somewhat common running the TST. They have not yet found a solution. It happens under extreme load at low RPM. Turn it down to where it is cleaner (smoke) and you will find a nice setting.
If you are searching for more low-end power, you wont find it with the regular TST programming, even at 9x9. There are other ways to achieve this.
Old Aug 1, 2006 | 11:56 AM
cquestad's Avatar
Don't load the motor at 1200 rpm's if you want to avoid that code. I have not seen it 1.5 years.
Bottom end on the TST will come from the MP-8 or a downloader.
Old Aug 1, 2006 | 06:02 PM
Leon441's Avatar
I think you may be on to something I missed. I tried building up boost and launching with engine cold just before seeing check engine light. The prior testing with TST on high levels may have had nothing to do with it sense the light did not come on then. I noticed the light after leaving buddies shop wanting to show off and engine was cold. Bet that had more to do with it than anything else. Thanks for insite.
Old Aug 1, 2006 | 06:14 PM
cquestad's Avatar
Cold only amplifies that problem at 1200 rpms...plus does wonders on head gaskets.
Old Aug 6, 2006 | 02:19 PM
tweeter's Avatar
If you go onto TST's website, they have a troubleshooting section, which mentions the p0336 code. I got a new injection harness from them under warranty for it and instead of getting the code every week, it has only happened twice in 8 months. Not perfect, but way less annoying. If your TST is under a year old, they may have a solution for you for free.
mjpalmer
May 19, 2005 11:34 AM
WhiteSport600
Dec 23, 2004 09:59 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
