Question Amsoil ATF
Old Apr 26, 2011 | 09:20 AM
bziggy's Avatar
Question Amsoil ATF
Just a question that I wanted to see some opinions on or if any one has done it. I have amsiol ATF in the trans and it's only got about 11000 miles on it. I had to replace a perssuer selinoid and while I was in there the trans filter. The fluid is not burnt and looks good ( maybe just a little silverish color to it) but look as good as when it came out of the bottle. I called amsoil and asked if it would be safe to reuse it and they said yes. They told me as long as it is not burnt or cooked and full of contaminates that it would be good to reuse. It's good for 50000 to 100000 miles. I wanted to know what people thought and if anyone had done it. It would be nice to reuse since it coast so much it buy it in the first place. Also it's a full synthetic so I would think it would still be good to use.
Old Apr 26, 2011 | 10:39 AM
Danderson's Avatar
As long as the container you drained it into was clean,you should be good to go. The factory fill ATF+4 is synthetic.
Old Apr 26, 2011 | 11:45 AM
Nate-03 D's Avatar
In terms of it being "worn", you're fine. Like mentioned above, I would only re-use it if it was caught in a clean container. Not just an oil pan that has been drained, something really clean.
Pig
23
Jun 4, 2010 01:01 PM
Mslaughter
Aug 24, 2006 06:44 PM
dieselfan
Aug 5, 2006 10:44 PM
Pig
Mar 13, 2006 09:12 PM
TPilaske
13
Sep 1, 2003 05:51 AM
