question about a smarty
Ok I am about to buy a smarty and I know these questions have already been ask. My questions are is it possible to use the smarty on more than just one truck? Does the smarty have the high idle feature?
as long as you don't have the smarty SW's loaded...you can move it from truck to truck...but if you load it on your truck then it will not work on your buddy's till you unload it.....I believe you can change high idle and tire size with out removing the SW's but I am not 100% sure....
I dont think the Smarty does the 3cyl warm up...just the PTO high idle
On their website for 2003 -2007 trucks it states: "Cold weather 3 Cylinder High Idle is enabled in all softwares " - what does that mean? Does it enable me to use the cruise control to idle up? Or is it something different?
I would go to the dealer and have High Idle enabled, but I tried that last winter when I purchased the truck and they were clueless... maybe I'll try a different dealer.
Your right about what the website says but sometimes they don't always explain things properly.
High idle using the cruise control is enabled on 04-07 5.9 cummins engines not 3 cylinder shut down high idle, not sure about 03 trucks. Maybe the 03's still had the 3 cylinder shut down feature, don't really know about the 03's.
Yeah I kind of figured after looking again, I saw the ** around the intake and exhaust and assumed the numbers were with just that.
skydiver41
03-23-2012 08:51 AM
stock03
34
04-21-2011 07:40 AM
jmccart
11-22-2007 07:43 PM
Mike Holmen
05-21-2007 10:21 PM
