quadzilla boost fooler
Old Sep 12, 2009 | 03:58 AM
stroker101's Avatar
need some help/advice. i have a BDTDPP stacked with a diablo PP on my truck. would it be safe to install the boost fooler (DTR store has it) with what i have already? will i see some increase in performance as well? any issue's?
thanks in advance!
Old Sep 12, 2009 | 05:57 AM
Dodgezilla's Avatar
Yes it will work since your Power Puck does not boost fool. You will get more boost and more top end power....
Old Sep 12, 2009 | 07:39 PM
stroker101's Avatar
well, ordered it earlier from DTR. i'm sure it will come with instructions but i would like to know up front...where will it plug in at? and if there is something else that is plugged in already, should the boost fooler plug in first or can it be piggy backed on whatever is there already?
thanks again for the help and education
Old Sep 17, 2009 | 07:40 PM
stroker101's Avatar
got the boost fooler today and installed it. took it out for a spin and the boost doesn't drop off like it used to when the tranny would shift to a higher gear. it continue's to climb up to around 40psi and then i need to get off the excellerator. good lord! this thing is awesome.
Old Sep 22, 2009 | 03:01 PM
zuki_dan's Avatar
General rule is to plug the boost fooler into the sensor last in line before the ECM that way other fueling boxes will read the true boost.
Old Sep 22, 2009 | 09:49 PM
stroker101's Avatar
i'll switch it around in the morning and try it that way. i was told to install it first on the MAP sensor. , thx
Old Sep 22, 2009 | 11:04 PM
qzilla's Avatar
That is true in some cases but, in the case of the puck we found that it doesn't make any difference. The tuning on the puck is pretty coarse and once you hit about 20psi it doesn't matter. The fooler does not start capping the boost that fast so it works fine.
Won't hurt to change it either, the results will be the same.
Killdmycobra
Nov 12, 2010 05:15 PM
dodgediesel
Oct 16, 2009 11:28 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
dieselpower04
Sep 25, 2006 03:22 PM
CDoskocil9
Sep 21, 2006 09:26 PM
