Commander Reading Lower Boost With New Quadzilla Boost Fooler??
Old Oct 15, 2009 | 07:45 PM
dodgediesel's Avatar
Question Commander Reading Lower Boost With New Quadzilla Boost Fooler??
Hi y'all. My Commander seems to be reading low now that I put a Quad boost fooler inline. I was wondering, does a guy have to now tap the boost fooler blue wire coming out of the MAP sensor side to make the Commander read the true boost?? Thanks for any help...
Old Oct 15, 2009 | 10:19 PM
Quad, any help with this one bud?
Old Oct 15, 2009 | 10:21 PM
Austin'sDodge's Avatar
If the quad reads the boost off the factory computer it won't read over 21psi of boost with the fooler installed.
Old Oct 15, 2009 | 10:27 PM
Where does a guy tap the Commander wire then??
Old Oct 15, 2009 | 10:33 PM
RUSSELLEE22's Avatar
you may be able to plug the quad in the map sensor first then the boost fooler then that should take care of it.
Old Oct 15, 2009 | 10:51 PM
The Commander is not a direct plug in type of gauges. It taps the blue wire of the Map sensor harness only with one wire. That's why I'm all confused..
Old Oct 16, 2009 | 11:33 AM
QPTRR's Avatar
You need to tap the dark blue wire on teh boost fooler that is plugging directly into the MAP sensor and the reading will be correct.
Old Oct 16, 2009 | 11:28 PM
Worked like a charm. Maxes out at about 42 psi..
norcaljr
13
Aug 5, 2008 10:13 AM
75woody
Jul 17, 2007 11:16 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
overcomer401965
16
Jan 13, 2007 06:10 AM
stock03
Nov 9, 2006 11:27 PM
