quadzilla boost fooler
Old Sep 23, 2006 | 10:33 PM
dieselpower04's Avatar
Exclamation quadzilla boost fooler
is there anything that I should know about this fooler before I purchase it.
Old Sep 24, 2006 | 11:17 AM
qzilla's Avatar
Only that if you are currently running your Juice with attitutde then you don't need it.
Old Sep 25, 2006 | 11:48 AM
yeah but it says that it's highly recommended with all programmers. since the juice is only programed to 32 p.s.i. this will over ride and allow up to 40 p.s.i. Atleast thats what in looking at. My EGT's are way high along with engine temps!!!!! I need to figure out a way to get them down.
Old Sep 25, 2006 | 12:28 PM
973604x4's Avatar
haha Quad
Dieselpower04- the key here is PROGRAMMERS. you have a MODULE. Modules DO boost fooling. you do not need a boost fooler, i don't think it will even work.
what temp problems are you seeing?
Old Sep 25, 2006 | 01:01 PM
qzilla's Avatar
Well it will still work but, I would worry about it messing with the Juice module. If you have a Juice and can only get 32psi you need to call them and have them send you a replacement. You should be able to easily hit 40psi with a J/A?
Don't get me wrong I love to sell parts but, in this instance you definately should not need one.
Quad
Old Sep 25, 2006 | 01:27 PM
morkable's Avatar
i hit 39 psi with my juice,, but that is according to the attitude,, will be getting my analog in this week
Kevin
Old Sep 25, 2006 | 02:44 PM
omaharam's Avatar
You have an old version. Call them and they will have you send it in to be updated. The updated version will give you about 38psi on the stock setting and 41psi on 1 - 5 settings. And by the way, my egts are high as well, even with 41psi with the HOT juice on level 5.
Quad
Never mind the last question in the pm I just sent, as you already answered it above.
Old Sep 25, 2006 | 03:22 PM
so I need to cancel my order then huh. thanks guys
Killdmycobra
Nov 12, 2010 05:15 PM
dodgediesel
Oct 16, 2009 11:28 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
andy3699
Nov 7, 2006 11:39 PM
CDoskocil9
Sep 21, 2006 09:26 PM
