Quad X2 XZT and Edge juice stack?
Old Feb 9, 2009 | 10:43 AM
OlRed's Avatar
I was wondering if anyone is running or has run the Quad Xzillaraider 2 XZT and Edge Juice Hot unlock with attitude stack. I am curious to see what the rail pressure runs at and if there are any known problems with this stack. Also if anyone has dyno #'s using this stack? Thanks for any info.
Old Feb 9, 2009 | 08:08 PM
omaharam's Avatar
480hp. It's a good stack. You need a lift pump to support it. I can't answer the rail pressure question because I didn't have a gauge then.
Old Feb 9, 2009 | 10:26 PM
diezel nutz's Avatar
I wonder why no one uses it, if its thats good of stack. I plan on using that stack also.
Old Feb 9, 2009 | 10:51 PM
OlRed's Avatar
Thanks Omaharam. What else did you have done when you had this stack? Just curious cause I would like to get to 500 to 550hp and still have it reliable and a daily driver. Thanks again.
Old Feb 9, 2009 | 11:01 PM
sloride's Avatar
I ran it and it was a strong stack but VERY toasty with a stock turbo. I no longer run the Edge but still stack the X2.
Old Feb 9, 2009 | 11:06 PM
OlRed's Avatar
What would your EGT's run cruising around and WOT? I will definitely be upgrading the turbo.
Old Feb 9, 2009 | 11:10 PM
omaharam's Avatar
I had an A3k turbo and a lift pump. Switching the xzt for an mp8 got me 505hp. The xzt had more bottom end help and the mp8 gave more top end and a higher dyno reading. mp8 might net a little faster truck but not much.
If you already have the quad, you can get a 64mm turbo and probably be right in the 500hp range. If you don't already have it and want to see the highest dyno number, I would get the mp8. Hot unlock, mp8, and 64 turbo should be in the 500-525hp range.
I like the Juice and the adjustability, but of course, if you got a Smarty and the turbo, those alone (with a lift pump) would put you 550+ depending on how good your stock cp3 is.
Old Feb 9, 2009 | 11:16 PM
sloride's Avatar
I don't remember my cruising temps but WOT would hit 1500+ at times and it didn't take long to get there.
sootindiesel
13
Mar 27, 2007 10:18 PM
SconsinSmoker
Feb 4, 2007 02:10 PM
VikingDiesel
Nov 15, 2006 12:24 AM
Big Horn
Mar 26, 2006 12:06 PM
razor6
22
Jan 20, 2006 03:43 PM
