Turbo is in.... But need some info
Old Feb 6, 2009 | 03:58 PM
Bswope's Avatar
Alright fellas turbo is in BUT IM STILL WAITING ON PARTS!
Anyway I cant get the drain tube all the way in the block, to me it looks like it needs to go in abit more cause i can still see the second o-ring abit!
Anyone have any suggestions or advice, ive been trying to get that dang thing in for the past hour probably!
Thanks,
Buddy
Old Feb 6, 2009 | 04:16 PM
homewrecker's Avatar
Get a small set of channel locks and adjust them so they dont squeeze the return line but are tight enough to rest on the lip above the o-rings and pull it down in place(do it from under the truck)
Old Feb 6, 2009 | 04:21 PM
bluechrome's Avatar
Lots of grease oil or any other lubricants help
Old Feb 6, 2009 | 06:07 PM
Bswope's Avatar
Man fellas I went back up to the garage and tried grease, think I got it but not sure, but Ill try the channel locks and see if it will seat alittle more!
Thanks fellas,
Buddy
Old Feb 6, 2009 | 07:40 PM
Blueboy's Avatar
If it isn't in all the way you will have oil
every where under your truck when
you test drive it. I took a long two by four
wedged it on top of line, an slowly pushed in.
This was after I went to car wash to clean
off the oil that leaked from line not being
seated.
Old Feb 6, 2009 | 08:10 PM
Riflemanusmc's Avatar
Registered user
Oh wait BROTHER Bud...........Did I say use GREASE???
OTFLMAO
Old Feb 6, 2009 | 08:14 PM
madhat's Avatar
Administrator/Jarhead
What I did...
I took a piece of 550 cord (heavy twine) and tied it in a loop around the oil line with enough slack to stick some 3/8ths extensions in, twisted the extensions to make it tight, then pulled down while I had a buddy reach through the wheel well with his hands on top of mine wiggling it a little. It was a pita, but it worked. I was laying on my back under the truck, and kinda did a chin up... I had one short 3" ext that I stuck in there first, and then put a couple 6" on either side...
hth...
Old Feb 6, 2009 | 11:17 PM
matego's Avatar
madhat's monkey boy...
Get this stuff. Its amazing how it works for stubborn o-rings
http://www.napaonline.com/NOLPPSE/(S(gzeaog55kprrqsvn0qd0b1rv))/Detail.aspx?R=BK_7651351_0006382692
Old Feb 7, 2009 | 05:00 AM
lmills's Avatar
Originally Posted by matego
hmm, I may have to try that stuff, ohh.... never mind.
Old Feb 7, 2009 | 01:33 PM
Bswope's Avatar
Man guys its in but Im not 100% sure its in all the way, its down in there and I cant see the second o-ring.
Matt I might have to go to Napa and get some, Napa, and a Fastenal is 10 mins from my house!
I tell you what that thing had me fired up and cause an uncontrollable array of choice words!
Old Feb 7, 2009 | 03:16 PM
rattlbox's Avatar
you freaking perv...lmfao....hey get two tubes of that ...roflmfao
Old Feb 7, 2009 | 04:01 PM
Registered user
OTFLMAO!!!! Sorry Lloyd, that was funny stuff right there..........
Old Feb 7, 2009 | 04:42 PM
Bswope's Avatar
CJ Ill get three!!
Dude you ever get your pump figured out?
Lloyd is a perv...
Old Feb 7, 2009 | 05:57 PM
Registered user
Originally Posted by madhat
What I did...
hth...
Brother....I'm RETIRED USMC...Most of these men have no clue
as to what 550 cord is.....I might thought..........
Old Feb 7, 2009 | 06:16 PM
madhat's Avatar
Not everyone speaks the lingo... Just trying to sound more educated and be more polite than I am...
Be a real man, don't use any lube... If you're strong enough, you won't need it...
