quad tow box throwing codes
i live at 8500 ft, no problems,
when i take the truck to, 10k feet, breckenridge it throws a code everytime cel comes on.
it usually throws the code when i start the truck after having been at altitude for a while, a few starts and sometimes it will clear, sometimes not,
with the box off running stock it doesn't throw codes so i am assuming it is the programming in the box. it never codes with the box off the truck
0069 is the one in the system regulary, but i have seen a few others
When I ran across colorado hwy 160 I hit elivation of 10900 with the xzt I had at the time and it was fine truck seemed a little lugged down but I'd exspect that.
Also since I'm here Quad my cb interfears even with it potted and under the hood. Only thing with it under the hood the control pod wire aren't long enough. So you got any suggestion for interfear. I tried pm but geuss it didn't work no big. Also my standard box started just after startup get a real quick 100rpm rev once or twice that normal seems to be fine other wise.
Sorry rockhound not tring to jack your thead
The little fluctuation at start up idle is normal. It basically takes a couple of milliseconds for the box to start working. During startup on some trucks it will make it jump just a bit when you start it. SHould not affect anything. It is usually on cold starts as well.
Cool quad thats what I was thinking. Like 06megacabman said the xzt did it too but I had it so shortly wasn't sure. 06 how you like it so far?
Also quad any suggestion on RF issue with cb if not I'll keep working my brain.
The only thing I notice is my boost is not as much as the xzt was xzt gave me 36-38max standard is 32-34 no biggy is still gits up and moves, also smoke is alot less too with standard.
Rockhound love your state Pagosa springs awsome, Wolfcreekpass 10987 gps just awsome.
ssleeper94
Nov 11, 2005 11:47 PM
badram
Aug 15, 2005 06:16 PM
gatf4
Mar 22, 2005 02:00 PM
