Quad Standard Box
Quad Standard Box
Hello everybody. This is my first post but I have been reading on here for years. I've got a question. Will the clutch and fuel pump in a 07 handle the quad standard box with no other mods except an intake and straight pipe?
This is with stock tires on a 3500 srw. Thanks in advance! Tony
Yes as long as you don't run the 100hp all of the time and then beat on it. I have been running the standard box on the 60hp for almost a year now (w/stock auto). No problems. On occasions the 100hp. On wot the fuel pressure will drop to almost 0 but that appears to be normal for 04.5trucks. So you should not have a problem. What a difference towing with the extra 60hp. Gauges will be needed soon. But I found that as long as I didn't step to deep into the pedal the egts were slightly better than stock. It seems I don't have to push as hard on the pedal with the extra horses.
I agree w/ NB64. I rarely use the 100hp setting because the truck just feels strange when I get into it for too long. It's either running out of fuel or the clutch is giving out, or both. My fuel guage never drops below 7 or 8 psi though. Mine has gotten the best mileage readings so far on the 60hp setting. What a huge difference in power that 60hp setting makes...
I just towed 2400 miles mostly on the 60hp setting. All I can say is WOW!!!! My EGTs did not get any better though while running the box....
Batts
14
05-05-2006 03:35 PM
Batts
13
04-30-2006 01:28 AM
Batts
04-04-2006 10:07 AM
badram
03-12-2006 02:47 PM
hoehand
14
11-16-2005 12:03 AM
