Pyro sender, remove manifold first?
I have a diesel mechanic who is going to install a Pacbrake that I just ordered. I asked if he would also install the pyro sensor for an Edge Insight CTS2.
I did my own pyro install on my old Ford 7.3. As I recall, I drilled/tapped the exhaust manifold in place with the vacuum and grease tricks to avoid leaving metal filings to find their way into the turbo. I had no problems.
For this truck, my installer refuses to do it this way. He insists on removing the manifold, drilling and tapping off the truck to ensure nothing gets left behind. It's a liability issue for him. Has anyone else done it this way?
I do not use the old grease on the drill trick. drill most of the way through the manifold, then start the engine and let it idle as you drill the last little bit. the exhaust will BLOW any chips OUT as you go through. be sure to wear safety glasses !!! you`ll be surprised how far the exhaust gas will blow the chips . there will be NO chips in the manifold. if you feel like putting some grease on the tap go ahead it will not hurt anything. let the engine idle as you tap the threads. I`ve done a couple dozen engines this way and have no problems. try it , you`ll like it and save a ton of money by not having to pay to have the manifold removed and reinstalled. if you are **** about it you can set the idle up to about 1000 rpm. and the chips will land in the next county, LOL !!!
Agree with it running works. When I did mine I was surprised that the chips hit my saftey glasses, didn't thing there would be that much pressure behind them.
There is no reason to remove the manifold from the truck.
Thanks. I thought removing the manifold seemed to be a bit of overkill. I drilled and tapped my Ford 7.3 with no issues. I never considered leaving the engine running. I guess I'll be doing this myself.
Thanks. I thought removing the manifold seemed to be a bit of overkill. I drilled and tapped my Ford 7.3 with no issues. I never considered leaving the engine running. Looks like I'll be doing this myself.
RoadDiesel
08-07-2012 06:06 PM
1985cucv
11-15-2009 12:17 PM
sallyman1
33
01-11-2008 09:41 PM
zooey69
15
03-02-2006 05:06 PM
Dodgezilla
07-17-2004 05:24 AM
