PS 62 Questions
PS 62 Questions
I just reiceved my PS62 turbo but I dont think that it is what I ordered. I ordered a 62/12 which I think is a PS6270CR. I opened the box and the tag on the turbo says 6280 3rd Gen which I think is a 62/14 is this correct?
I use this truck every day for work usually with Juice on 3 and EZ on 1 and I occasionally turn everything up when I am feeling a little frisky. Should I send this turbo back or will I be able to spool this turbo fine?
have i got a deal for you. i have a 62/12 phatshaft on my truck right now, but i run a pressure box and a diablosport, and it spools super fast but i can push past the wastegate when it shifts to od. it's set at 40 psi but with stuff turned up and the extra load of od it goes up to about 50 psi. put yours on and see if you like it, if not we can switch exhaust hsgs, if you want. mine has only about 400 kms on it. i would just try it though, you migh like it
Turbocrazy
Feb 25, 2013 04:40 PM
popeye4wheeler
Jan 30, 2011 06:24 PM
Clucker
22
Sep 24, 2009 09:34 PM
GR40RCapri
Oct 30, 2007 09:37 AM
gman07
Apr 15, 2006 08:32 PM
