Proper place to drill for pyrometer
On second gen, #6 cylinder runs the hottest, so we put ours in the rear divided flute just before the turbo. I don't see why it would be way off if you drilled closer to the hottest cylinder, but if you drill way up front by #1&2, you will get cooler egt readings. The biggest advantage that I see just before the turbo is that you get an average of all cylinders.
Ah64id, what if #5 injector hangs up just enough to rise egt's an extra 300* but you can't pick it up because you are only testing first three cylinders?
That's what I think. In my last truck I ran two pyros, one for the TST and one for my Isspros. The TST was right above the turbo picking up the rear cyls, the other on the top picking up the front three.
Mine never seemed to be more than 50°-100° apart.
My new gauge is going to pick up from the front three. Until I run some big power I'm not going to worry about it. Later, though, I'll be running two pyros.
i have been reading up on where and how to mount my pyro. right now it is mounted in the down pipe so after the turbo and i am putting a new down pipe on the truck so i was going to put the probe in the right spot but i dont know i just dont know how safe i feel about drilling into the manafold like that with the shavings and what not can any 1 help me out and give me some advice on doing this? thanks
Here's a neat, easy trick for those worried about drill/tapping debris getting in the turbo: Unbolt the turbo from the manifold, allowing it to drop down enough to slide a little piece of cardboard in between the turbo and manifold, blocking off the turbo. Drill and tap to your heart's content, forget the grease. Start the engine for two seconds, blowing any debris out on to the floor. Re-assemble, finished. You might want to change the gasket, they cost like $2.
I agree with the warm part.. but not the running part. What if the bit breaks or a piece stays in the manifold.. it now hitting tubro blades at idle rpms.
Brian08Q35004x4
Feb 1, 2011 04:37 PM
Strjock81
Dec 9, 2007 12:36 PM
sandpuller2004
Oct 14, 2005 10:17 AM
