problem with predator..
Old Dec 5, 2006 | 12:08 PM
danimal 95's Avatar
after dissconnecting my ignition switch to fix a wiring problem the truck wouldnt start again,i had to download the factory program back in it in order to get it to start.called diablo this mornong and they really didnt have much to say about it.im a little hesitant to reinstall the program worried about it not starting again and mabey damaging something else.any thoughts???
Old Dec 5, 2006 | 01:02 PM
Dan Marino's Avatar
Read my post about what I found out. Could be what I experienced.
Old Dec 5, 2006 | 01:24 PM
danimal 95's Avatar
which post would that be???
Old Dec 5, 2006 | 02:57 PM
morkable's Avatar
https://www.dieseltruckresource.com/...d.php?t=126598
Old Dec 5, 2006 | 03:11 PM
danimal 95's Avatar
looked at your post and its really not the same problem....my truck was driven into the shop with the tune installed 3 hrs later would not start till i put the factory tune back in.I am concerned with the possibility of the programmer now having a problem and not loading correctly when i try to put the progam back in
Old Dec 5, 2006 | 03:29 PM
streetsmoker's Avatar
If your relly that cautious, just send it to Diablo, as they have a great return policy, and let them check it out.
Old Dec 6, 2006 | 07:31 AM
Dan Marino's Avatar
The way I understood the guy I talked with was that the cummins will 'forget' sometimes. He said it usually happens when not being used for awhile but that it could happen anytime. He said if the tool says to reload original then what it is doing is resetting itself. If you successfully reloaded original (and the truck runs) the way I understood the tech - you can try to load a tune.
I can understand how you feel. I didnt want to touch mine either when it acted up on me.
Old Dec 6, 2006 | 07:43 AM
danimal 95's Avatar
thanks for the advice,i took the risk last night and tried to put the the program back in and it worked fine truck started right up,thanks again
Old Dec 6, 2006 | 07:51 AM
Dan Marino's Avatar
Good deal. Glad its back for you.
Old Dec 6, 2006 | 06:13 PM
I just run mine on the Extreme tune all the time don't even worry with the lower setting anymore the power is so smooth. I even tow with it in that setting.
getpower
Feb 5, 2015 05:22 AM
Israel Sweeney
30
Jul 3, 2008 01:39 AM
bziggy
13
Jan 6, 2008 11:00 PM
Bweb91
13
Nov 9, 2007 10:26 AM
DMS1707
Jul 21, 2007 07:42 PM
