Is it Possible???
Old Feb 17, 2007 | 08:01 PM
PurNLoud's Avatar
Question Is it Possible???
Can any of yall tell me how I can remove my factory installed clamped together exhaust without cutting it? What I want to try is to seperate the sections, somehow clean out the cat, and put it back up. Can this be done? I live here in Willis, TX now, and nobody will inspect it if there is no cat on it, so I figured I would leave it, just have it completely empty. Please give me some input yall, I have to have help on this one. Thanks yall.
Old Feb 17, 2007 | 08:02 PM
3500lly's Avatar
I know there is no way to remove it post cat without cutting it, not sure about pre
Old Feb 17, 2007 | 08:45 PM
PurNLoud's Avatar
Sorry to bump my own , but anyone???
Old Feb 17, 2007 | 09:56 PM
mikelr's Avatar
Why not just cut it then weld it back up afterwards, or you could use some of those "band" type exhaust clamps that seal 360 deg. You can do butt splices on exhaust pipe with that type of clamp.
Old Feb 17, 2007 | 10:59 PM
Sam Turner2's Avatar
cat
why don't you cut the exhaust right after the cat, take a punch and beat the $hit outa the inside of the cat, crank the truck to blow it out and then have your local mufflers shop, or you, weld the pipe back on or a straight, ect.
Old Feb 17, 2007 | 11:01 PM
4x4not's Avatar
If you had access to an oxy-acet torch you could heat it cherry red and beat on it with a BFH....
Old Feb 17, 2007 | 11:15 PM
acook's Avatar
Or my favorite a BFP(pipe)!
Old Feb 18, 2007 | 06:28 AM
oil_burner's Avatar
there is a joint just bhind the crossmember ,it's a PITA to get to but loosen that up a wiggle it around .It's goona take some time but with lots of wd-40 and time it will come apart. This is for off-road use only right ?
Old Feb 18, 2007 | 06:47 AM
OT-OF-Here's Avatar
No problem
You'll need a torch. Just heat the outer pipe at each connection. At the muffler you can use a block of wood and a big hammer and knock it back. At other connections after heating I use an old large channel-lock and grabl hold and hit it right after taking the heat off the out pipe and it should come loose without damaging the pipe.
Old Feb 18, 2007 | 08:19 AM
Derek Timm's Avatar
Don't know about your truck but mine had the factory clamps on so tight the tubes were crushed togeather.
After trying just about every thing here the sawsall came out and finished the job.
DT<*)))><
Old Feb 18, 2007 | 09:36 AM
PurNLoud's Avatar
thanks yall, lol to some I think I am gonna try to cut it at both ends and then use the 4"clamps to place it back up, then let the shop weld it back on. Of course it is for off rd use only, off the rd I go!! I'll keep yall posted on how it comes and if it is even worth doing. My exhaust just smells like bad vineger, so this has to help!! Thanks again yall
Dwight
Mar 18, 2003 08:14 PM
wildcard3766
Mar 16, 2003 07:38 AM
AlpineRAM
Mar 10, 2003 05:47 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
TPilaske
Oct 24, 2002 08:24 PM
