PO531 Code
P0513-SKIM INVALID KEY ERROR **weird that code links me to this P0513 instead of the p0531***
WHEN MONITORED
Key on
SET CONDITION
Invalid Key Code received from SKIM Module
POSSIBLE CAUSES
WHEN MONITORED
Key on
SET CONDITION
POSSIBLE CAUSES
- General network error
- Key not programmed
- Incorrect key
- Incorrect VIN IN ECM or SKIM
- Loss of communication between ECM and SKIM
P0336-CRANKSHAFT POSITION (CKP) SENSOR SIGNAL
WHEN MONITORED
With the key on.
SET CONDITION
The voltage detected at the Crank position sensor is below a calibrated value.
POSSIBLE CAUSES
WHEN MONITORED
With the key on.
SET CONDITION
POSSIBLE CAUSES
- CKP sensor
- (K24) Signal circuit open
- (K853) 5-volt supply circuit open
- (K975) Return circuit open
- (K24) Signal circuit shorted to (K975) return circuit
- (K853) 5-volt supply circuit shorted to (K975) return circuit
- (K24) signal circuit shorted to (K853) 5-volt supply circuit
- (K24) signal circuit shorted to ground
- (K853) 5-volt supply circuit shorted to battery negative
- Intermittent condition
- ECM
If the RPMs on your tachometer bottom out (your tachometer reads zero) while driving, it's your crankshaft position sensor. It causes hard starting if it's on the fritz because it initiates the fueling cycle from the injection pump.
O.T
Sep 6, 2007 06:10 PM
CTD NUT
Apr 5, 2005 04:45 PM
