Pics of my Homemade Intake Horn and 2 Micron Filter Setup
I pet my truck from time to time....
Thanks YelloZ. I was just wondering if running a water sep. only filter, in addition to a 3 mic. OEM replacement would be pretty close to the filtration delivered by the 2 mic. systems; and perhaps better than the 5 mic. Baldwin (which I was actually getting ready to order before I saw this thread).
I would run the 5 micron baldwin in the stock location and then run an additional filter after it. You can choose which filter to run, but the setup or hard goods will remain the same. I can run any number of filters using the setup I have now.
I actually have the 7 micron fleetguard filter in my stock location now and I have an extra one already so I will be putting it in when I change it.
I plan on sticking with the Baldwin filter that I have as the secondary filter for a while and I will buy a replacement for it later down the road, just not sure if it will be another Baldwin or the Cat or Donaldson that ah64id listed
Looks to me like the Multi-Pass rating or beta rating is the industry standard.
http://www.filtercouncil.org/techdata/tsbs/89-5R3.pdf
Where did you get all the specs about the filters?
The only company that says they use multi-pass for fuel is Baldwin, everyone else uses single pass. (Baldwin has both specs, but as you can imagine multi-pass ratings are better, so they publish those).. Multi-pass is fine for oil, hydraulic, etc.. pretty much anything in a closed system. But there is a change your fuel will only get filtered once before being burned.. I want single pass ratings.
Yeah those specs are almost impossible to find. In case anyone else is interested in duplicating the additional filter setup, these are the components that I used, I used the FP take off fitting because I was running a fp guage, if you aren't going to run one you can skip it or buy it, plug it and save it for use at a later date.
Russell 670650 RMA
Adapter Fitting; Flare Reducer; Straight; 10 To 6; 2 @US$7.88
Russell 670510 RMA
Adapter Fitting; Flare To Metric Adapter; Anodized; AN Size -6; 12mm x 1.5; 2 @ US$3.97
Russell 670340 RMA
Specialty Adapter Fitting; Fuel Pressure Take Off; Anodized; AN Size -6; w/1/8 in. NPT Side Port; 1 @ US$9.99
Russell 610160 RMA
Full Flow Hose End; 90 Deg. End; Anodized; AN Size -6; Center Line Radius .5 in.; 4 @ US$13.99
Aeroquip FCA0606 RMA
AQP Racing Hose; 6ft. Hose; -06AN Dash; 0.34in. I.D.; 0.55in. O.D.; 1000/750 PSI; 2.5in. Min. Bend Radius; 0.16 lbs. Per Foot; 21in. Per HG; 1 @ US$31.95
Got it all from street side auto they had the best prices at the time, but you can shop around and decide which brand you want to use. Plus you will need the filter base I posted earlier. This is just what I used and should work for you too, but I take no responsibility if it doesn't work for you.
Russell 670650 RMA
Russell 670510 RMA
Russell 670340 RMA
Russell 610160 RMA
Really like the filter setup! Hope you don't mind me playing devils advocate here... what exactly are the benefits of such a setup vs. the stock fuel filter or are you running this in tandem with the oem filter/housing? Forgive me if I missed something but I began to wonder what you were using for a lift pump, water blocking and the water in fuel sensor? Also what do the spin on filters sell for?
I have a similar setup to what yelloz28 is running, the stock filter, sensor, and heater are all in tact. I run the stock LP.
I like your set-up and I'm not trying to start anything here. I picked up the same Baldwin filter head at a Big Truck Supply/parts place next to me for $13, (plus tax here in Taxachusetts), also get all my oil and fuel filters there.
I've been using a BF1212 that they (at the truck store) told me it was 4 micron. Plus they sell me a PF7977 for the stock filter cannister that they was a 5 micron. Can you tell me if this is correct and where I can get the spec's on Baldwin filters?
Also use the Baldwin BT7349 oil filter.
I was thinking of picking up another filter head and adding a 2 micron filter after the my stock filter, before the CP3.
The PF7977 is absolute at 5 microns, which is funny he told you nominal for the 1212 and absolute for the 7977.. The 7977 is nominal at 1-2 microns.
I get all my baldwin specs thru emails with Baldwin.
You could mount it with the stock horn in place, GDP actually sells the mount, if you go to their site you can see it. I believe it works with the stock horn or their aftermarket one.
ovrszd
24
04-23-2011 04:14 AM
1985cucv
16
04-20-2009 04:27 PM
03RAM2500
01-11-2009 05:21 PM
OldSmokey
29
02-25-2008 10:06 AM
