P0071 & P0513?
My edge brought up theses 2 codes today:
P0071= Ambient air temp sensor performance.
P0513= Invalid Skim.
Does anyone know exactly what this means and if it is anything that i should worry about? Also does the Slip% work with manual transmissions? It flashes from N/A to 0% when i put it on my display. Thanks in advance guys/gals!
P0071= Ambient air temp sensor performance.Oil from the AFE dirtying up the sensor???
P0513= Invalid Skim.this seems to come up now and then, mine has come up before
Try cleaning the IAT senor with some sensor spray.....
Thanks 53 ****** ill try that,Ive found out that p0513 is a code fora disturbancein the RF between the truck and the chip in the key. And i guess dealer cant explain it. Go figure!
My truck just did the skim thing too. Did you ever get anything figured out with it, or did it go away when you cleared the code?
