p0071 code
Old Nov 14, 2006 | 12:52 PM
NR_Teacher's Avatar
p0071 code
Anybody know what this code is for on a 2001 three quarter ton?
Old Nov 14, 2006 | 02:39 PM
79warlock's Avatar
Battery temp sensor performance. There is a flash for it, TSB# 18-011-01.
Old Nov 14, 2006 | 11:05 PM
NR_Teacher's Avatar
Whats a flash? Could it be the code for Ambient Air Intake Temperature Sensor?
Old Nov 15, 2006 | 11:28 AM
79warlock's Avatar
It's a software update for the ECM. The codes is listed as Ambient/battery temp sensor performance under service info but when you read the TSB it specifically says the code is for battery temp sensor.
Old Nov 15, 2006 | 02:52 PM
NR_Teacher's Avatar
I looked up the flash on Dodge.com, it says that the code is for gas engines, this p/u is a deisel. Does it still apply?
Old Nov 15, 2006 | 04:37 PM
79warlock's Avatar
OOps, you are correct. I must have selected the 5.9 gas when checking. In that case, you are looking for a bad battery temp sensor or wiring. It is located under the battery in driver side battery tray.
Old Nov 15, 2006 | 06:46 PM
NR_Teacher's Avatar
Thanks Warlock, in the future how do I know about the codes without havin ta come here?
Is there a chance the code could be for Ambiant Intake Air Temp? I had some other guys tell me thats what it was.
Old Nov 15, 2006 | 07:02 PM
79warlock's Avatar
I am a DC tech so I get my info directly from printed or online service manual. I believe the intake temp codes are P0112 and P0113. If you have an ambient temp sensor, it would only be an input to overhead consol, not ECM.
Old Nov 15, 2006 | 11:08 PM
NR_Teacher's Avatar
Thankyou Warlock, you have helped tremendously!
jmccart
Jun 4, 2007 04:22 PM
shane156
May 8, 2007 07:52 AM
beardedone
Dec 24, 2006 06:25 PM
Derek Timm
Jul 27, 2006 03:01 PM
