Older BD Twins
Guest
Posts: n/a
Older BD Twins
I have the possibility of getting a used set of 2G BD twins. I have been told that the twins even though were built for a 2001 model were installed on a 2003. If that is the case then they should fit a 2004 (305/555). The set will come without the exhaust manifold and will not have the tube from the compressor to the intercooler. Is there a shop in the NC area that can fab the required parts and install these for me on a 2004? Will this setup work properly and are there any known problems with using an older turbo setup on a 3G truck? I have tried to access the BD forum site with no luck. I was told a manifold from a 98-2002 will be required. Any help finding a good shop to do the install would be appreciated. Thanks.
nfsommer
10-13-2007 11:20 AM
Stock 02
28
09-24-2006 11:09 AM
