NV5600 short shift kit?
Old Nov 16, 2008 | 02:32 PM
0524VHO's Avatar
Went to the track for the first time this weekend, and im lookin into short shift kit for my 5600. Also a weighted shift ****. Who makes a good kit, and if your runnin it, how do you like it?
Old Nov 16, 2008 | 03:51 PM
0524VHO's Avatar
bump bump bump
Old Nov 16, 2008 | 05:47 PM
0524VHO's Avatar
bump anyone?
Old Nov 16, 2008 | 06:27 PM
StealthDiesel's Avatar
I have a NV5600 with the BD short shift kit.
I think BD is the only company that makes a short shift kit for this tranny.
I've had it for over 3 years and I really like it but I had to make other changes also.
The BD short shift kit moves the shift pattern to the right, away from the driver. This was not comfortable for me.
I ended up purchasing a Whiplash shift stick from these guys in Washington state. It was around US$100.
http://www.profinishinc.com/html/for_sale.html
The new bent stick moves the pattern over to the left by about 5 inches and the rubber isolator in the bottom of the stick is welded up.
The stock shifter is hollow and would not be easy to bend without kinking.
The shifting is great now with the Whiplash handle & the BD short shift tower. Comfortable, smooth and short shifts.
Removing the rubber isolator in the shift handle is what really made the difference though.
I would start with the new stick 1st and go from there. Also don't purchase the new handle from Pro-Finish with their chrome "paint" finish.
It peels off from the high wear areas. Just paint it black or have it chrome plated.
...Joe
Old Nov 16, 2008 | 06:57 PM
shineboy2's Avatar
I'm running the BD kit and really like it.
Old Nov 16, 2008 | 07:08 PM
rip 112's Avatar
Got the BD kit too and like it, but honestly I could row through the gears just as fast with it stock.
Old Nov 22, 2008 | 05:19 PM
shineboy2's Avatar
...Joe
What do you mean by the rubber isolator?
I love the looks of that shifter and am going to look into getting one.
Old Nov 23, 2008 | 07:33 AM
COUNTRYBOY's Avatar
I love my HURST Shifter, it brings everything over to me... Have it coupled to the BD short shift kit... Pics in my gallery
Old Nov 23, 2008 | 08:06 AM
MikeyB's Avatar
Cool. Do you have a P/N for the Hurst stick?
Oops, I see it in your sig.
MikeyB
Old Nov 23, 2008 | 10:52 AM
If you have a close look at the stock NV5600 shift stick you will notice that at the end that screws in the shift tower is actually in 2 pieces.
The part that screws into the shift tower is mounted inside the shift stick and isolated by rubber. This is where most of the vague shifting comes from. The Pro-finish stick has this welded up. If I had to do it again, I would weld up the stock stick before buying the BD short shift kit. This will tighten up the shifter also.
The Hurst shift handle is not a simple bolt on. An adapter is required. Tomeygun did engineer & sells a kit to do this..
http://tomeygun.com/
I don't see this kit listed on Geno' garage any more but the instructions are still there.
http://www.genosgarage.com/installat...RSTShifter.pdf
...Joe
Old Nov 23, 2008 | 03:34 PM
dogger's Avatar
BD short shift
I'm running the DB short shift kit and really am a little disappointed with it. Someone mentioned that this kit moves the pattern to the right some which true and in stop and go traffic getting to the starting gear is a little tough at times. Better modifications to spend money on.
L8r,...........dogger
Old Nov 23, 2008 | 05:11 PM
shineboy2's Avatar
Thanks Stealth... I know what you mean now.
Old Nov 23, 2008 | 05:42 PM
0524VHO's Avatar
I thought the bd kit was supposed to move the stick closer to the driver?
Old Nov 23, 2008 | 08:09 PM
rip 112's Avatar
IMO it didn't move anything right or left for me but rather up. The shifts are shorter but like I said it didn't seem to speed anything up, mainly because with that short shifting is also notchier shifting and getting into gears are a little more tricky, the other thing is the movement of the shifter from right to left is stiffer, reverse takes a little more effort to get past the lockout. I guess I'm used to it now, so I won't be removing it.
6BTchev86
Oct 20, 2010 10:29 PM
caltom
Mar 28, 2005 08:42 PM
cummins dsl
13
Feb 14, 2005 08:20 AM
yannick
Jan 31, 2005 08:51 AM
HighTen
Sep 22, 2004 10:09 AM
