Is it ok to short shift a NV5600?
Hey I was just wondering if it is hard on the tranny to short shift a NV5600 6-speed? It is in a 05 Ram 2500. I have heard both way. One says it is ok not to use clutch and the next said it is hard on the synchro's? So for hauling it is nice because you keep it spooled for longer with out the lag. It feels really good like a big rig. Dosent grind just dont want to hurt anything as the replacement cost is alot more than a clutch!
Short shifting has nothing to do with not using the clutch. But if you want to know what guys think about shifting without the clutch then there's plenty of threads regarding that topic.
I dont see how it cant have anything to do with the clutch? The clutch is engaged a lot fewer times in it life span which should lengthen the life of the clutch. Mainly I am worried about the tranny? Tried seaching for threads but nothing for my situation came up.
As I said, "short shifting" has nothing to do with not using the clutch. You're simply asking if its OK to not use the clutch. And sure, maybe, you might extend the life of the clutch some even though most clutch wear occurs during take off, not shifting, but its the life of the syncros which you will reduce by doing this. Then again, I'm not sure what your situation is either since you didn't seem to find any info regarding.....and the topic gear floating has been hashed out plenty.
Yeah, you are saving some clutch material but wearing your blocker rings(synchros) a lot faster.....so it is said on numerous posts re: this topic in the past.
Clutch $$$
Blocker ring R/R $$$$$
Your choice.
Clutch $$$
Your choice.
Ok sweet that is what I have heard that you arent supposed to short shift a synchrnized tranny just wanted to make sure! Guess I have never heard it called gear floating? Searched that topic and it is pretty clear! Yep a clutch is alot cheaper and easier than a tranny rebuild!! Thanks
DJ Turbo.
Nov 5, 2011 12:20 AM
0524VHO
13
Nov 23, 2008 08:09 PM
blackdiesel
Oct 19, 2005 11:51 AM
Eddy Reyes
Jun 4, 2004 08:53 AM
Mexstan
Mar 23, 2003 02:57 PM
