New stage 3 floor it cp3
Old Jan 24, 2008 | 03:10 PM
  #61
revolution_dsl's Avatar
besides, if these are too big, ill get another smaller set cut free...no losses but time
Old Jan 24, 2008 | 03:50 PM
  #62
omaharam's Avatar
Originally Posted by cquestad
Why, why, why not use something a little more proven?
Flux 3.3's crank over and start asap with no grids and no block heater at 0...
Hold the phone!
You aren't running a grid heater in Idaho in the winter?
How in the world does it start?
Old Jan 24, 2008 | 04:10 PM
  #63
cquestad's Avatar
Fine...i never plug in or even wait for them to cycle. My grid is still in right now..but will be out when my CP3 multiplies.
I have been testing the starting without the grid cycle to make sure BEFORE I spend MORE MONEY.
Old Jan 24, 2008 | 04:14 PM
  #64
im running 80hp sticks now, i dont wait for mine to cycle in 3 degree (last night) weather. starts fine like it was 80 degrees out.
Old Jan 24, 2008 | 04:15 PM
  #65
Luvnacumns's Avatar
Really wow... I keep mine plugged in and the last three days it's been four below zero and my grid heater still kicks on for about 5 seconds...
Cq... did you get my message?
Old Jan 24, 2008 | 04:18 PM
  #66
JD Dearden's Avatar
I havent had to start mine yet this winter
Old Jan 24, 2008 | 04:21 PM
  #67
Luvnacumns's Avatar
You suck!!!!
Old Jan 24, 2008 | 04:25 PM
  #68
cquestad's Avatar
The grids only kick on becuase the IAT sensor tells them too for emissions and warm up purposes once the engine is running. If you drove off right away and went over 20 mph they would shut off asap.
I did get your message Shane...we can do the swap in Daves heated shop...
Thank GOD!
Old Jan 24, 2008 | 04:34 PM
  #69
Luvnacumns's Avatar
Thank GOD!
Sweet... that's good to know... NOt to hip on the negative temps and swapping cp3's!!!
Old Jan 24, 2008 | 04:55 PM
  #70
PEAKSTRYDE's Avatar
In a perfect world with no budget, wouldn't the truck be happier with a dual fueler setup apposed to a single moded pump???
Seems like the correct way..................
Old Jan 24, 2008 | 06:41 PM
  #71
tristan21's Avatar
so is anybody runnin two modded pumps or one modded and one stocker
Old Jan 24, 2008 | 07:40 PM
  #72
curtisvillectd's Avatar
Johns stg.2.5 on the bottom stock duramax on top works real well.
Old Jan 24, 2008 | 07:42 PM
  #73
one modded and one stock seems to be the trend...if youve got all the money in the world, sure why not go cp3x2?
Old Jan 25, 2008 | 12:03 AM
  #74
Sloverado's Avatar
I don't run grids either!!
Old Jan 25, 2008 | 10:41 AM
  #75
ramtd02's Avatar
ramtd02...I hope you choose your "new" turbo wisely...so it might last a little longer.
Please post your dyno graphs w/o correction please...
Yep new turbo will last much longer......and i will gladly post my dyno sheet, just as i did with the 62!!
