Nelson/Donaldson/Rokktech mufflers... real gains?
Old Feb 16, 2007 | 01:51 PM
msiminoff's Avatar
I have searched through all of the posts here about cat-back exhausts and replacement mufflers. There is a definite consensus that with my 4" exhaust, a cat-back system is not necessary and of course there are lots of posts about having a "louder" exhaust and avoiding "drone"...
But what I haven't seen is actual data supporting claims of increased torque and/or HP. Has anybody done a before/after dyno test with any of the replacement mufflers? What were the *REAL* gains (if any) and what RPM are you seeing them at.
Thanks
-Mark
Old Feb 18, 2007 | 01:59 AM
msiminoff's Avatar
So based on the the fact that this post got zero responses... Am I to assume that there are no real HP/torque gains available by replacing the stock muffler with an aftermarket one on an otherwise stock '05 CTD ?!?!?!?
Old Feb 18, 2007 | 02:46 AM
jmccart's Avatar
I have read manyh tech articles where they dyno before after a muffler install, they always get mo
re power. Do ya' want noise or no?
Old Feb 18, 2007 | 03:16 AM
mikelr's Avatar
Mark,
I know that you are asking for "real" dyno proven results and unfortunatly I can't provide you with that.
I can say however that my 07' woke up considerably after dumping the stock exhaust system and installing the 5" turbo back with 51" Donaldson muffler.
The power when the truck was stock would nose off around 2400rpm when rowing through the gears. With the new exhaust I can feel a bit more pick up but what is more notable is that I have to watch the tach because the truck will run up past 3000rpm and it will pull till the ecu defuels. Obviously the truck is breathing much better and the fact that it is still pulling beyond the piont it used to with the stock exhaust would equate to a higher HP number on any dyno.
BTW, there is absolutely no drone with this setup.
Old Feb 18, 2007 | 03:18 AM
TexasCTD's Avatar
My truck bone stock from the factory dyno'd 280/528 on a dynojet in the summer heat.
After adding an AFE Stage 2 air intake and 4'' straight thru Magnaflow muffler and no cat......it dyno'd 277/549 on the same dyno a year later.
To answer you question directly......You will probably see no gains by doing an exhaust upgrade alone. However, once you add boxes/downloaders etc. the air and exhaust mods will help things flow better.
The exhaust mod is basically a "supporting" mod and doesn't add power in and of itself. That is my experience anyway.
Now with the Smarty on level 9....mine dyno'd recently at 466/922. Hope that helps.
Old Feb 18, 2007 | 04:07 AM
mikelr's Avatar
Originally Posted by gdh11
Does anyone have any suggestions for reducing drone on a MBRP 5 inch system. I have heard of resonators that can be added to quiet it down but I have not found any. I dont want to reduce the EGT advantage just all the noise and drone. Thanks.
Cut out that MBRP muffler and strap on a Donaldson.
Old Feb 18, 2007 | 04:27 AM
TexasCTD's Avatar
Maybe you could try having your exhaust tip extended to see if that helped. Also, maybe a turndown tip?
Old Feb 18, 2007 | 07:34 AM
MikeyB's Avatar
The only real gain to be had with a high flow exhaust is a slight drop in EGTs.
Neither intake or exhaust will increase power on a stock truck, but it does help when going for higher hp.
MikeyB
Old Feb 19, 2007 | 08:08 PM
rjm022's Avatar
big rig shops sells donaldson mufflers. look in your local phone book for a peterbilt, kenworth,etc dealer/parts dept. i paid around 60.00 bucks for mine alittle more than a year ago.
RedRacer44
Jan 29, 2007 10:09 AM
turbopilot51
26
Nov 10, 2006 08:02 PM
jnck
Apr 5, 2005 12:49 AM
CTDinMT
May 18, 2004 03:45 PM
Mexstan
Mar 24, 2004 05:29 AM
