Need some input on RPM over redline...
Old Aug 31, 2008 | 10:47 PM
justin mcfall's Avatar
I was pulling a 8-11% grade friday, i pulled the truck down to second gear manually,and the rpm's went past redline to about 3500rpm for about 3-5 seconds. The truck runs fines, i was just wondering if this would do any damage? Thanks..Justin
Old Aug 31, 2008 | 11:44 PM
jlibert's Avatar
since you weren't under high boost when it happened, probably not. valve to piston contact can happen in some situations, but you're probably fine.
Old Aug 31, 2008 | 11:49 PM
Thanks J.P. I am glad to hear it. I know the 5.9 can take some abuse, just didn't know how much.
Old Sep 1, 2008 | 04:20 PM
XLR8R's Avatar
The CTD has a 100% duty cycle at rated speed - 3500 RPM.
Old Sep 1, 2008 | 04:28 PM
Jason Foster's Avatar
The auto tranny should have an electronic interlock on downshifting at too high RPM. You should be able to downshift to first and the tranny won't shift until the engine can handle the RPMs.
Old Sep 1, 2008 | 04:41 PM
JDiepstra's Avatar
If it makes you feel better there are programmers that raise the RPM limiter to 4000 on the HPCR's. There are some engine mods you should do first though.
CumminsRedneck
Oct 13, 2014 04:49 AM
1985cucv
Jun 12, 2010 09:41 AM
Checkmate
Mar 23, 2008 09:10 PM
bigfoot
Aug 14, 2004 02:22 PM
fishin fever
Feb 22, 2004 08:32 PM
