Need Advise on Possible Overdrive Clutches Slipping
Old Oct 27, 2004 | 09:36 AM
AK RAM's Avatar
Can anyone who has experienced overdrive clutches slipping explain what that feels/sounds like? I tried an insane power combination yesterday and experienced some bucking in overdrive at WOT above 2K RPMs. The truck pulled extremely well in overdrive up to that point. The road was wet due to rain and initially I thought the tires were breaking loose as it felt like short, consistent jerks. I put the truck in 4X4 high and tried it again and same thing. Next thought was that the combination just wasn't working and the engine was cutting out. I can't remember exactly what was going on with RPMs at the time as I thought about this after the fact, but I don't remember the RPMs fluctuating downward during this, leading me to believe the engine was not cutting out, but maybe the overdrive clutches were slipping. They are still stock and have been seriously abused, so I'm leaning in that direction. I just don't know what kind of symptoms that would produce. I assume there is not a way to verify that they are slipping without tearing into the trans.
That leads to question number two. Given that they are "overdrive" clutches, I assume they are not in use unless your in overdrive. So, if it is an engine/fuel problem, it should be reproducible at the same RPM level in say 3rd with overdrive locked out….correct?
Thanks.
Old Oct 27, 2004 | 01:34 PM
PourinDiesel's Avatar
Yes, they were slipping.
Eventually you will lose OD all together if you repeat the process to make them slip.
You need to modify your tranny.
I would already suggest a rebuild.
Old Oct 27, 2004 | 10:11 PM
AK RAM's Avatar
Thanks for the response. Figured it out.
Old Oct 29, 2004 | 06:57 PM
J Double's Avatar
Originally posted by AK RAM
Figured it out.
So what did you figure out?
Old Oct 29, 2004 | 07:06 PM
AK RAM's Avatar
That my truck is faster than yours. ...and that I need to start saving my money.
Old Oct 29, 2004 | 07:18 PM
J Double's Avatar
If it's not drivable I can always give you a ride to work in my Dxx equipped truck.
Let me know If you need Toms #
Old Oct 29, 2004 | 07:33 PM
AK RAM's Avatar
That's just wrong. They were stock clutch packs for crying out loud.
Old Oct 29, 2004 | 07:39 PM
J Double's Avatar
I know...just thought I'd rock the boat a little.
Now's a good time for that Billet input so there's no excuses at the next test and tune
Old Oct 29, 2004 | 11:53 PM
AK RAM's Avatar
Rock'n the boat huh. I'm working on something for you.....just wait.
Old Oct 30, 2004 | 12:40 AM
J Double's Avatar
Why do I get the distinct feeling I'm going to need to spend more money
Old Oct 31, 2004 | 02:10 AM
AK RAM's Avatar
Old Oct 31, 2004 | 02:14 AM
J Double's Avatar
ROTFLMAO.....you got to much free time on your hands AK. Good one.
Old Oct 31, 2004 | 02:15 AM
AK RAM's Avatar
matt69olds
Jan 20, 2013 07:32 AM
tomd
Feb 8, 2009 01:28 PM
72demon440
Apr 27, 2007 10:45 PM
06dodgedrw
32
Oct 31, 2006 11:50 AM
solid_st8
13
Mar 31, 2006 07:23 PM
