need advice on what to do
ok, my mods should show, I hope, Ihave had problems for as long as i can remember, go thru injectors every 4, 5 , or 6 months have at least one go bad, i dont race alot, I use my mods for pulling, I do this for a living, usually run my quadzilla on next to last setting, 100 hp, and seem to have less problems, but when i do go to 140, and get into it, almost always throw code, fuel delivery error, and seems this is when i damage injectors, and this last ime, actually waiting to see, might have lost a cylinder, my egts hit oh littl over 1400 for about 2 seconds or less, and when i stopped, i noticed rough idle and then oil loss, and blowby, but my question is, are other having problems with the quad 2 xillerator race, on high, have an air dog system, but my thinking is at high my stock cps is starvint the injectors for fule, so heating them up, and buring them out? could some one tell me what to do to make it safe to run high setting, or is the proper safe way to quit the chips and build with pumps and injectors, not trying to make a street machine, just pull safely, and well play every now and then when some one comes up cocky, lol I have not seen alot of problems on here with the quadzilla users, so why am I having so much?
you probably need to install a modified cp3 fuel pump on your engine, do you have a rail pressure gauge? when these injectors run low on fuel they will be damaged for sure! due to the system these injectors run on to make them work under the high pressure, i am higly knowledgeable and work with these injectors, if you need to know details you can PM me.
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
ryan466
Aug 30, 2006 10:10 AM
v8440
14
Sep 7, 2005 08:39 PM
olchevrepl
20
Oct 29, 2002 08:14 PM
