need a used skidsteer! need advice
Old Aug 19, 2006 | 02:46 PM
rjm022's Avatar
in the market for a used skidsteer. in the 10,000 to 12,000 dollar range. i have found a couple of deals lately-but i wanted some feedback from you guys first. any particular brand better than others?? also- which diesel engines are better thans others? kubota? perkins,etc?
Old Aug 19, 2006 | 02:49 PM
blackdiesel's Avatar
Registered
how big of a skid steer are you looking for? like a good condition - smaller one or a decent(needs-some-work) - bigger one?
Old Aug 19, 2006 | 02:52 PM
Registered
and ill admit (before it becomes apparent) that i dont know much about them. However, i have ran a few. It was a 260 john deere, slow as heck, but would pick up rocks bigger than you could fit in the bucket. Were talkin about a ton and a half to 2 tons.
What are you planning on doing with it?
Old Aug 19, 2006 | 03:04 PM
linetrash75's Avatar
Get a Case I have run JD, Bobcat, New Holland,and Case. Had one at a fertilizer plant that i worked at had 9000 hrs on it and no major repairs. they made the bucket bigger to load trucks quicker it would lift the world. Plus they have Cummins 4b in them.
Jed
Old Aug 19, 2006 | 04:00 PM
Registered
Jed
cant beat that!
how much are they though?
Old Aug 19, 2006 | 04:08 PM
rjm022's Avatar
looking at something the size of a bobcat 763-which i believes has a 48hp kubota.
Old Aug 19, 2006 | 05:40 PM
carcrz's Avatar
I bought a Case 1845C a couple years ago for 8K. We put some new hoses on it & did every bit of fluid & lube maintenance possible & she has ran like a champ. Never had any problems other than flat tires.
Old Aug 19, 2006 | 05:46 PM
rjm022's Avatar
thanks carcrz-i'll check into that model
Old Aug 19, 2006 | 06:00 PM
carcrz's Avatar
Just make sure, if you get model, that it has the "c" as it has a taller reach for loading higher.
Old Aug 19, 2006 | 07:05 PM
rjm022's Avatar
gotcha ya! thanks again!
Old Aug 20, 2006 | 04:17 AM
PistolWhipt's Avatar
I will second the motion for the Case 1845C. Ran one for years and they are great little loaders. I really like having all of the controls on the hand sticks instead of having to use your arms AND legs to operate it like on the Bobcats.
P.S. Did you see the New Holland for sale in the DTR classifieds ???? I think it is in your price range but not sure about location.
PISTOL
Old Aug 20, 2006 | 06:27 PM
BCB's Avatar
BCB
We run a bobcat S185, 743 and a Bobcat 430 trackhoe. The S185 is alot nicer to run then the 743 but it was also 55 grand but for the $ a Bobcat 743 can't be beat! It is the prodessesor to the 753 and 763 what makes it better then those to is it is geared lower in the drivetrain. So it just tends to dig better if you will back off on the sticks a lil. If you are looking for somethin new/bigger we had a 773 befor the S185 and that was a great machine.
I would stay away from New Holland. I have seen a few and talked to several operaters that ran them and they are a nightmare to work on! You about have to about pull the motor to change the battery! While I was at our local Bobcat dealership a brand new New Holland came in on a rollback with about 250 hours on it. It just died on the owner for the 6th time he told us that he had nothing but problems out of the loader and the dealer was so over loaded with work that they couldn't get it fixed. So they pretty much just ignored him.
Overal the way i see it you can't go wrong with a Bobcat that has been taken care of.
Old Aug 20, 2006 | 07:17 PM
Marine's Avatar
Veteran: Marine Corp
We bought a Bobcat 873 for the ranch- the bucket lifts straight up. I had JD (6675 if I recall properly) come out, and there was no comparison. Also, the JD pump was WAY more expensive to replace if it crapped out.
I didn't look at the Case, and Cat did not have a skid steer back then.
hitcb1789
May 25, 2010 09:10 AM
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
xtoyz17
Jan 31, 2008 12:16 PM
hoghead
Jan 9, 2007 04:10 PM
Math_Teacher
Apr 26, 2004 04:22 PM
