need advice w/ edge attitude w/ mon stacked w/ EZ
Old Mar 22, 2006 | 09:31 PM
bigsilver's Avatar
Question need advice w/ edge attitude w/ mon stacked w/ EZ
my question is... which is the better way to hook up the edge's.hook the EZ before the attitude or after it and also my truck kind of i guess you would say stall in first and second but in third its all you can do to hold on to the steering wheel from all the power any answers on what to do. By the way trying to get the truck in the low 13's to high 12's any help there would be great too.
Thanks BS
Old Mar 22, 2006 | 09:36 PM
edge600's Avatar
Fill out your sig, so we'll know everything you have already.
Old Mar 23, 2006 | 09:45 PM
bigsilver's Avatar
opps
maybe this a help. BTW got a torque mangement and speed eliminator out of JEGS (couldn't find it any where else) think itwill help with how the trans is acting.
Old Mar 23, 2006 | 11:02 PM
RamWheelsBy4's Avatar
I plugged in the Juice first, the EZ into the Juice pigtail and the stock connector into the EZ pigtail. Ran that way for good while with no issues at all. Very smooth consistent power.
Old Mar 23, 2006 | 11:07 PM
JCLeary's Avatar
Thanks BS
If you're indeed running a Juice module on your '03 in your sig, you don't want to stack with an EZ.
The '03-'04 Juice modules increase rail pressure, as does the EZ, so sooner or later you're going to have some rail relief valve issues.
The only "safe" way to get the power you're looking for with a Juice is to have it upgraded to the "HOT" version, but you still have to run it as a stand-alone unit.
If you have an 04.5 and up, stack away and have fun!
Old Mar 24, 2006 | 05:12 PM
bigsilver's Avatar
I have checked on the "hot" for the Juice and they don't have it for the 03 305 H.o. i dont belive. I'm little bit of a dealer in my home town for diesel performance and the last time i checked with edge they only offered it for the 04.5 and up. Also will i need to upgrade some of my transmission components if I add the snow STAGE II kit? BTW it is an edge juice w/ attitude.
Old Mar 24, 2006 | 05:28 PM
Capp35's Avatar
Called recently and they do have the Hot program now.
JcClearly is right.
Edge says don't stack those two boxes or you will cause problems for the 03-04 models.
Old Mar 24, 2006 | 11:04 PM
bigsilver's Avatar
JcClearly is right.
Thanks fellas, ill call monday and check on the HOT upgrade.I'm so glad i'm a member of the DTR just for this reason. I'll take the ez off tomorrow and get the HOT upgrde as soon as they can do it. Any other suggestions will be great.
Old Mar 25, 2006 | 12:03 AM
SmokinDodge12V's Avatar
How much HP does the HOT Juice add and has anyone ran it with a Bully Dog Power Pup. Thanks
Old Mar 25, 2006 | 08:12 AM
Capp35's Avatar
It offers an advertized increase of 50hp.
blue2002
0
Sep 20, 2011 08:16 AM
Justwannabeme
Nov 9, 2008 06:46 PM
reidsram
Feb 10, 2007 05:06 PM
Timinva
16
Feb 20, 2003 09:03 AM
