My Xzillaraider messed up!
My coolant guage seems to go over 200* very easily now (with moderate accelleration just up to 55mph). This is new in the last 2 weeks. I rerouted the harness wires and checked and double checked all the connections been getting hot ever since.
Any thoughts?
Jamie
Any thoughts?
Jamie
What I ment to say was it is more or less spiking up 50-100* past the 200 mark. It's never done that before with the box on for the last several months. It's new since rerouting the wires three weeks ago.
I don't know.
Jamie
I don't know.
Jamie
If I were you I'd check all my connectors, maybe try running with the box off and the bypass in, try to pin point whats causing the spike in your temp guage. Or call and consult Quad. They will definaltly try and help you out.
When on the 100 or 140hp setting I can also get my temp gauge to move up over 200, which it will NOT do when on 60hp or stock settings. It's clear the box gets the engine hotter - and no surprise. The fact you say you didn't have it before and have it now makes me wonder if you just never noticed it before or not Jmac? Is it possible you paid less attn to that gauge before?
I to have the standard box and am having some issues with my CB. whenever I key the mike the truck will shut down and here latley I have the SURGE thing going on. Hope we can get this ironed out. I'm waiting for Jeremy to get back on this.
Jim
Jim
Lightman, I have paid close attention to the guages on the dash from the beginning and this is definitely new... I need real guages. I'm going to double check all my connections today. then drive it on the off setting and see what happens.
thanks Jamie
thanks Jamie
OK so I test drove the truck with the bypass plug in and it still overheats for a short period of time (5-10 seconds and it stabilizes back at 199*). This is still new in the last 2-3 weeks. If had a little too much oil in the motor, (2-3mm past full) would that cause this spiking. I've over filled the motor oil by accident in the past (about 29K miles ago) and all that happened was rough idling.
BTW truck ran quieter and smoother with the box removed FYI.
thanks for any thoughts,
Jamie
Jamie
KEEP ON TRUCKING!
usmcduncan001
Sep 14, 2007 04:10 AM
beandrew
22
Jan 28, 2006 02:29 PM
Jeremy Cusick
Sep 15, 2005 10:14 AM
