MPG and POWER question?
Old Feb 5, 2008 | 04:00 PM
zack birge's Avatar
I have 35x13.50x20 Procomp Extreme a/t on my truck now and i was wondering how much difference it would make if i went to 37" tires next time i need tires? And what kind of mpg will i be looking at? Better or worse?
Old Feb 5, 2008 | 10:46 PM
zack birge's Avatar
Just wondering if i would lose alot of power and also get worse mpg too? ANy Ideas?
Old Feb 5, 2008 | 10:50 PM
jwb600's Avatar
I would think it would be worse because most tires the bigger it is the heavier it is. I had a mickey thompson atz 35/13.50/20 for a short time on my truck and removed them because of the way it drove. I know those tires weighed 80lbs each so im sure those didnt help the fuel mileage any. im not sure if this helps but its something to look at. most tire websites state the weight of the tires and you can compare what you have now and the tires you are looking at. if they are close in comparison your mileage may not change much
Old Feb 5, 2008 | 10:56 PM
Luvnacumns's Avatar
Honestly on my 05 I went from 33's to 37's and didn't loose any... But I was just running a quad zxt with the 33's and the 37's I was running crazy larry... So the power gain was significant... The added bonus was cruising rpm's!!!!
Old Feb 5, 2008 | 11:14 PM
zack birge's Avatar
Im only gettin around 12 to 14 now so i really don't want things to go downhill at all it already cost enough to fill the thing up! it would be better if it was still stock when i was gettin around 18
Old Feb 6, 2008 | 07:00 AM
HotRodK's Avatar
Smile
I never did find a way to get great mileage from my '06. Im averaging about 4mpg better in my '04 now using the same BD tuner on the same performance setting. The newer trucks just dont MPG as well..
Old Feb 6, 2008 | 10:54 AM
zack birge's Avatar
It sucks because i was getting around 18 before i lifted my truck and put the tires on it! My buddy has a 01 and he only gets 12 stock not lift or tires and its only 2wd!
Old Feb 6, 2008 | 10:58 AM
RamWheelsBy4's Avatar
You will loose some power and mpg. Power difference may not be very noticable going from 35s to 37s, but bigger, heavier and more rolling resistance takes more power to get going. MPG will suffer in city type driving, but may be close to the same on the highway. Just my experience.
Old Feb 6, 2008 | 11:12 AM
zack birge's Avatar
Is there any way i can take my five inch lift back down to like a three without having to but a complete new lift? So i can run 33's
Old Feb 6, 2008 | 11:16 AM
Man that would depend on the lift kit installed, my guess is that it would be difficult. I am sure the right shop could do some custom configuration with some of the kit, but might be easier to remove and go back to stock height.
I removed my leveling kit and went back to stock height to run 33s. Mileage and handling is definitely better on 33s than 35s for me.
Old Feb 6, 2008 | 11:23 AM
zack birge's Avatar
Yea i wish i would have started out with just a leveling kit because the mpg went down hill after the lift! Especially towing!
I just hate to see the green be wasted by taking the lift back off!
bngcustoms
45
Jun 20, 2009 06:55 PM
richard
26
Sep 6, 2007 01:35 PM
bigfish5
Sep 19, 2006 12:56 AM
rockhound
Nov 15, 2005 06:10 AM
micah
Sep 9, 2005 12:05 PM
