Banks Torque Converter
Old Feb 4, 2008 | 10:21 PM
zack birge's Avatar
Unhappy Banks Torque Converter
Got my new banks torque converter in a couple of months ago and it seems to be "shuttering" when it goes from first into second gear! ANy body know why that is caused?
Old Feb 4, 2008 | 10:28 PM
zack birge's Avatar
Just got my new banks torque converter in a few months ago and it seems to be "Shuttering" any idea on what could be causing this?
Old Feb 4, 2008 | 10:38 PM
Lrdchaos's Avatar
Probably not the reply you wanna hear, but it's a banks product. It's overpriced for what you get. What level have you been running your pda on? Also did you do a vb when you installed your tc? Plus you have a lift and 35's, all that adds stress to your drivetrain.
Old Feb 4, 2008 | 10:40 PM
Lrdchaos's Avatar
If it's shuttering from first to second, I don't believe it will be your tc. Have you had the bands adjusted?
Old Feb 5, 2008 | 06:55 AM
zack birge's Avatar
no it didn't do it though until i put the tc in!
Old Feb 5, 2008 | 09:15 AM
kantdrive55's Avatar
DTR Advertiser
With the 1-2 shudder it most likely is going to be either a band adjustment or a pressure issue. The converter isn't going to have a noticeable shudder until the lockup clutch applies which would be in 3rd and 4th. Like mentioned before have the band adjustment checked and also have the main line pressure checked. This should give you a good idea of what is going on. You might also want to check your u joints and drive shaft bolts. They could be loose which could cause a similar feel.
Old Feb 5, 2008 | 10:56 AM
zack birge's Avatar
okay thanks for the help!
Old Feb 5, 2008 | 11:03 AM
DTR Advertiser
No problem.
Old Feb 5, 2008 | 11:09 AM
zack birge's Avatar
How would i adjust the pressure if thats what causing the problem? Would i need a new valve body or just need to adjust something?
Old Feb 5, 2008 | 11:20 AM
DTR Advertiser
Depending on how low the pressure is you might be able to adjust it, or if the pressure is way down you actually need to rebuild it. The valvebody can only help to bring things up so far. The front pump is basically doing the majority of the work. Any time you go to a more efficient converter it is always a good idea to do a valvebody at the same time. Banks wont tell you that because they dont have one.
Old Feb 5, 2008 | 11:22 AM
zack birge's Avatar
I normally run it on level five! I use it on level five when im towing my boat to! I don't have a aftermarket valve body at all, its still the factory one!
Old Feb 5, 2008 | 12:43 PM
zack birge's Avatar
oh okay i see so i should probably get a aftermarket valvebody? IF so which is best for my needs.
Old Feb 5, 2008 | 01:23 PM
Lrdchaos's Avatar
Most of the aftermarket vb's are good. I went with a hts vb, and I don't have any complaints. You can't go wrong with hts, dtt, or goerend. I would stay away from the purple money eaters......
Old Feb 5, 2008 | 03:12 PM
zack birge's Avatar
Okay great! If i get a vb would i have to take it to a trans shop to have it put in or what? When you say purple money eaters do you mean "ats"
Old Feb 5, 2008 | 03:30 PM
jwb600's Avatar
im gonna second what he said. any of those would be a good buy. I know hts prefers to run a suncoast converter with their transmissions or converter upgrades they do. my HTS has done me very well and holds power great
