mp8 questions
mp8 questions
i just bought an mp8 and i am planning on stacking it with my smarty but i dont have the smarty on the truck right now and when i put the mp-8 on it, i can have it turned clear up to 100% and i dont even notice that much of a difference between 0% and 100% and it doesnt even hardly smoke at all. i dont know if im just used to the smarty but i usually keep it on 5(90hp) and the smarty on 5 i kno has more power than the mp-8 on 100%. i have checked connections and everything. do you guys kno anything that could be wrong or do u have any experience with these thing? thank you!
I have noticed only a slight difference bewteen 0 and 100 with just the mp8. If I have the edge on level 4 and the mp8 on 100, I get more smoke than with the edge running alone. If I just run the mp8 by itself it won't smoke as much. I have also noticed with the windows up and stereo off, the engine will fuel less when turning the mp8 from 100 to 0 while driving, the tone of the engine will change. I think someone asked about the fueling of the mp8 but I can't remember what thread it was. I think they said that the mp8 just brings the fuel on earlier or something like that.
My Mp-8 Smokes Until Turbo Is Spooled Then Stops Until About 30psi Then Smokes Again But Not Black More Like Dark Grey...i Plan To Stack W/ A Smarty Or Triple Dog. I Havent Decided Which Will Be Better For Me...
So in other words it would be a good box to run until I get my tranny built? I plan on stacking either Bully dog or a smarty w/ the MP8. They say 100 hp but real world maybe 30-40hp more, right?
i would not run the mp8 over 40% seen too many destroyed injector tips from too much pressure, esp if you run a cp3 mod. keep it moderate and you should have no pressure problems. just my .02
Anytime you run pressuer, you should have a 2micron filtering set up. It's the dirt particals that cracks the injecters under pressure, not neccessarily the pressure itself. And for what's it's worth, I run my mp-8 on about 60%.
82NDSNPR
42
Oct 10, 2008 12:28 PM
smoky beast
28
Oct 13, 2006 01:15 PM
Igor
May 10, 2006 09:19 AM
masonic-dodge
15
Apr 22, 2006 01:21 AM
whatdieseltoget
Dec 6, 2005 10:23 PM
