MP8 question?
Old Nov 9, 2008 | 06:53 AM
Bswope's Avatar
MP8 question?
Ok fellas just for Craps and giggles, if i came upon a good deal on a MP8 for my truck would u ****** it up? And would i benefit from it, i mean i have the TST/Smarty stack now but heard alot of good stuff about the MP8.
Thoughts?
Thanks,
Buddy
Old Nov 9, 2008 | 06:56 AM
Hintz's Avatar
Yes! MP-8 will had a couple thousand on your rail pressure adding extra HP. And since its adjustable on the fly turn it on kill when you want to smoke someone on the street. To answer your question youll notice a nice SOTP increase.
Old Nov 9, 2008 | 09:11 AM
d-turbo-d's Avatar
I was wondering the same thing about the mp8 and I also have the tst/smarty(tnt). I only run the smarty (and love it) and leave the tst on 0 because ive read that it can be a deadly stack for your motor, any truth to that? Maybe we would be better of with smarty/mp8 only.
Old Nov 9, 2008 | 09:24 AM
Bswope's Avatar
The #'s in my sig was with Smarty TNT on SW#7, TM 4, Timing 2, RP 3 and wastegate off and the TST R49 on 2/0 standard program! Ive been running the TST with the Smarty for sometime now and havent had one issue, i think as long as u dont get to crazy with the TST u should be fine. Lots of settings so just be careful! I try to write down what settings i try that way i know what works!
Oh the #'s were with stock turbo, stock sticks, stock Cp3.
Old Nov 9, 2008 | 01:02 PM
J-man's Avatar
I've heard nothing but good about the mp-8 and would love to have one myself!
Old Nov 9, 2008 | 01:05 PM
madhat's Avatar
Administrator/Jarhead
Just watch your rail pressure. If you don't have a RP guage, I would not do it. Too much RP can be really bad.
The deadly part is the timing... the MP-8 does not add timing.
I have an MP8, and love it!!!
Old Nov 9, 2008 | 01:15 PM
justin allan's Avatar
I would not leave the driveway with out my MP8 !!!
Old Nov 9, 2008 | 02:35 PM
trx's Avatar
trx
Ok some how much pressure is too much? What does the tnt produce with rp settings on high? Have a rp guage on the way just wondering what I should be seeing? TIA
Old Nov 9, 2008 | 04:08 PM
Bswope's Avatar
I run one or the other, meaning i either use the Smarty for timing or the TST, but never both at the same time.
So if i unplug the rail pres of the TST i should be able to use the MP8 for added pres right?
Old Nov 9, 2008 | 04:25 PM
madhat's Avatar
I would not go over 27k at the most with out a capped and modded rail.
Old Nov 10, 2008 | 08:21 AM
trx's Avatar
trx
Has anyone had problems with there MP 8 working properly? I know this is just a plug in type box but i heard it does not always work and some have had to send theirs back, any truth to that.
Old Nov 10, 2008 | 08:28 AM
soulezoo's Avatar
DTR 1st Sergeant
I run the power puck with my smarty /TST stack and have the TST plugged into the puck inline-- actually, TST first, then puck; that way I get accurate rail pressure reading.
Old Nov 10, 2008 | 09:13 AM
madhat's Avatar
I do not have any experience with the TST... you should be able to leave it in, just adjust it off the RP guage. As long as you don't turn it up over 26.5k, you should be jammin... Like I said, I don't have any experience with the TST, so I could be wrong...
Yes... common problem is people turning the connectors the wrong way, I think it's the MAP that looks the same either way, and connections not being seated right. It sounds like a cammed out gas motor. (ask me how I know? )
Another problem that I had was the wires coming apart at the connector, and I just re-spliced them.
Call TS performance if you have a problem... they had great customer svc when I used them.
Old Nov 10, 2008 | 09:58 AM
JCLeary's Avatar
You want the MP-8 plugged into the MAP sensor before the TST. The MP-8 does some tricky MAP value fooling that gets your TST (and ECM) to think that there's more boost than actually there at low boost readings. It will make your TST fuel sooner since the TST fueling is boost-dependent. It smoothes out the hit from the TST big time. It will also cap max boost readings, so you don't have overboost codes.
For the rail sensor you'd want the TST plugged in first for accurate readings, then the MP-8.
The MP-8 is the best pressure box. I tried them all in my '03.
Old Nov 10, 2008 | 07:23 PM
Bswope's Avatar
Thank for all the info guys! If i run across a good deal for one im gonna give it a try!
Roebuck9
Aug 6, 2008 07:35 PM
wap
Jul 6, 2007 11:21 AM
hazer04
Jan 14, 2007 02:03 PM
hazer04
Oct 20, 2006 12:28 PM
smoky beast
28
Oct 13, 2006 01:15 PM
