Mp8 Question
Old Jul 16, 2006 | 07:45 PM
hazer04's Avatar
Mp8 Question
i have a bdpp and iam trying to stack it with the ts performance mp8 box.after starting the truck and taking off down the road i can only hit 10lbs of boost and i get a low boost code and a ecm error code,any ideas would help thanks!!
Old Jul 17, 2006 | 03:52 AM
Its All Good's Avatar
What have you tried yet? have you tried it with the mp-8 disconnected. Double check all the connection. Another thing to check is the jumper wire pins in the correct location.
Old Jul 17, 2006 | 08:45 PM
hazer04's Avatar
ive doubled checked everything,tried just the mp8 box,all the same results
Old Jul 18, 2006 | 04:14 AM
Dodgezilla's Avatar
Did you put the Dielectric grease on the connections?
Old Jul 18, 2006 | 08:32 PM
hazer04's Avatar
that i did not do,you really think that would cause my problem
Old Jul 19, 2006 | 04:14 AM
Dodgezilla's Avatar
The directions tell you that you will probably have issues if you don't do this. They give you a tube with your box.
Old Jul 19, 2006 | 09:51 AM
cquestad's Avatar
I have never used any grease ever on any connections...on any box. MP-8, VA's, Edge EZ and Juice, TST, etc and NEVER have had any problems...just clean plug to clean plug.
I think there is something else wrong. I bet some pin is bent...or not hooked up correctley, something got unplugged during the install and was not plugged back in, or the switch was wired wrong from the factory (happened to a couple of them).
Try driving with it unplugged...and see if the truck is still fine...to rule out anything else first...then,
Call TS Performance.
Old Jan 14, 2007 | 02:03 PM
hyunsinsone's Avatar
i just bought a new mp-8 and i have an 06 dodge and when i turn the dial from 0 to 100% there is no difference i put the jumper wire in the 5 and 6 hole that is wut my paper said. is that right i have checked all the conection and every hting is fine wut could be wrong. thank you
Bswope
14
Nov 10, 2008 07:23 PM
Roebuck9
Aug 6, 2008 07:35 PM
wap
Jul 6, 2007 11:21 AM
hazer04
Oct 20, 2006 12:28 PM
smoky beast
28
Oct 13, 2006 01:15 PM
