MP8 & Quad Boost Fooler??
Old Nov 6, 2009 | 04:52 PM
dodgediesel's Avatar
Question MP8 & Quad Boost Fooler??
I'm going to be adding a TS MP8 to the mix and already have a Quad Boost Fooler. Can I run both or should I remove the Quad? Does the MP8 boost fool even if it is in the off or lowest position? Thanks for any ideas or tips...
Old Nov 6, 2009 | 08:12 PM
Spooler's Avatar
MP8 does boost fooling. Really no need for the Quad boost fooler.
Old Nov 6, 2009 | 09:19 PM
Just wondering if it will still boost fool with the MP8 off or does it really have an off position??
Old Nov 7, 2009 | 12:13 AM
Spooler's Avatar
Not sure about the MP8 when it is turned off.
Old Nov 7, 2009 | 12:24 AM
Hmmmmmmmmmmmmmm...
Old Nov 7, 2009 | 02:14 AM
jlibert's Avatar
as long as the mp8 is on at least 1%, it won't throw codes. When I have it all the way down, it will throw overboost codes. Ditch the quad, keep it above 1%.
-jp
Old Nov 7, 2009 | 11:07 AM
-jp
I guess that should be save for daily driving too? A guy should obviously run the Smarty TNT on stock rail pressure too??
Old Nov 7, 2009 | 12:35 PM
Redsmoke's Avatar
what does the quad boost fooler do exactley?? can some one explain
Old Nov 7, 2009 | 04:37 PM
jlibert's Avatar
Get a rail pressure gauge. Keep it around 18-19k for extended periods of time (i.e. highway driving). With the smarty on stock rail pressure, you'll probably be somewhere around 10-30% on the mp8 to achieve this pressure.
Old Nov 7, 2009 | 10:03 PM
I have the Quad commander. My pressure is around 17k on the highway, 22k WOT and 6k idle on TNT #9
Old Nov 7, 2009 | 10:10 PM
diesel4play's Avatar
It modifies the boost pressure signal to the ECM fooling it into thinking the pressure is lower and therefore the ECM allows you to make more boost. This gets you higher boost for very little money. I think you will need a separate boost gauge of some sort to see you actual pressure.
Old Nov 8, 2009 | 05:38 PM
With the MP8, where does a guy tap into for rail pressure? I'm tapped onto the blue wire at the plug now but do I now tap onto the blue wire on the MP8 side closest to the rail pressure sensor?
fullthrottle07
Jan 19, 2008 12:09 AM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
rkelley
19
Jan 11, 2007 10:59 PM
973604x4
22
Oct 22, 2006 09:08 PM
smoky beast
28
Oct 13, 2006 01:15 PM
