muffler inside single stack?
Old Nov 6, 2009 | 07:44 AM
mike moore's Avatar
In addition to a hushpower muffler just after the cat,what about installing another small muffler or resonator inside the 6" stack? fairly simple fabricate.Have the 4" pipe that comes thru the bed continue up thru the stack for 6 inces or so,weld a resonator or muffler with a diameter smaller than 6",slide the stack over your work,secure the stack to the bedplate.Anyone done this?
Old Nov 6, 2009 | 07:33 PM
RamWheelsBy4's Avatar
Not exactly. I have an Aero Turbine 5050XL (built in resonator) after my down pipe and a 6" single miter stack cab high. I have installed one of the in-stack mufflers in the stack. Very little difference, maybe a little less noise at cruising speed, but not much. They are cheap so every little bit helps.
With the Cat still on and a hushpower you are probably as good as your gonna get. Just my thoughts.
Pic of in-stack muffler:
Old Nov 8, 2009 | 08:20 PM
mike moore's Avatar
Im just gonna leave like 12 inches of 4 inch pipe sticking up into the stack,if its too loud then i can weld some dampning inserts in the 4" pipe.
mike moore
Oct 28, 2009 08:06 PM
Patrick Campbell
Mar 23, 2005 01:29 PM
2500CTD
Dec 21, 2004 02:47 PM
faster_than_ford
Mar 15, 2004 01:25 AM
