Muffler vs. no muffler vs. stack (90 degree bends)
Old Mar 22, 2005 | 10:53 PM
Patrick Campbell's Avatar
How much power is lost with the 2 90 degree bends required to do a single passenger side stack?
Right now I have a 4" downpipe to a high flow muffler dumped right out of the muffler with a 45 degree bend. (no bends around the axle)
Will I gain anything or lose anything going from what I have now to a single stack, no muffler?
I've only found stacks in 5".... seems kind of dumb to go from 4" to 5" since my downpipe is only 4". .. but maybe that 5" helps a little on the 90 degree bends?
Is there such thing as a 5" downpipe? Is there enough clearance (4" is tight here) even?
Old Mar 23, 2005 | 01:11 AM
joefarmer's Avatar
I don't think you'll loose anything noticable by adding 2 smooth flowing 90s in the exhaust stream (.0001 hp?).
Yes, there is such a thing as a 5" down pipe, but you'd need to be running a very large charger or twins to have an exhaust housing that large. (The B2 for example).
brandon.
Old Mar 23, 2005 | 11:45 AM
Korney's Avatar
Makes no difference since the exhaust is only 3 inch off the turbo where it matters most. Anything after that is show and tell.
Old Mar 23, 2005 | 01:29 PM
BDR2500's Avatar
Well that's good to know, now I can upgrade to 5"
subs1000w
Jun 6, 2007 06:10 PM
StrokeThisCTD
Jun 17, 2006 08:28 PM
00turbo
Jan 15, 2006 03:18 PM
gunracer1
Oct 12, 2004 05:07 PM
