single stack with hush muffler
Old Oct 26, 2009 | 10:03 AM
mike moore's Avatar
anyone heard a 6 " single stack with a hush muffler? I want to put a single 6" stack on my rig cut just below the roofline,but dont want to go deaf in the process. I plan on leaving the cat,installing a 20" hush muffler,and using grand rocks single stack with internal baffle.I currently have an mprp muffler and it sounds great,but the truck really needs a single stack.Can it be done without being unbearable in the cab.I dont tow to often an when i do its only about 3,ooo lbs.
Old Oct 26, 2009 | 11:47 AM
rich's Avatar
its still gonna be loud even witha muffler these trucks make some noise
Old Oct 26, 2009 | 12:02 PM
mainiac's Avatar
i run that setup. noisy but bearable at all speeds. passengers don't complain too bad. big difference vs not running a muffler. noise has increased since install though.
Old Oct 26, 2009 | 03:35 PM
homewrecker's Avatar
Don't waste your money on the internal stack muffler.They are a joke.I tried them out and they only made the slightest of difference.Not worth the money
Old Oct 26, 2009 | 06:52 PM
mike moore's Avatar
If there is a better method or muffler I'm open for suggestions.I love the stack look,but not if i go deaf every time im in the truck.
Old Oct 27, 2009 | 07:16 AM
05CTDN8's Avatar
If you can find a muffler that will fit (i believe the AERO4040xl or the 5050 will fit) between the down pipe and your 90* you will be fine....but still it gonna be loud!
Old Oct 27, 2009 | 07:59 AM
rich's Avatar
put it a little higher then the cab,is the only thing i can think of to get the noise down
Old Oct 27, 2009 | 12:09 PM
surfram's Avatar
Found these hushpower+stack videos on youtube:
Edited because of profanity in comments section
http://www.youtube.com/watch?v=kY2e_KBVRP4
http://www.youtube.com/watch?v=rUpEbMee3ag
Old Oct 27, 2009 | 12:46 PM
mike moore's Avatar
thanks for videos,gives me a good idea what im in for.they do sound real nice. its tough to get an idea of there actual sound cause no one around here has stacks.
Old Oct 27, 2009 | 01:15 PM
AlCorr's Avatar
Thanks for videos, I was thing of doing something like that, but maybe not now after seeing the videos, too loud for me inside the cab.
http://www.youtube.com/watch?v=y_t7df--i20&NR=1
This is crazy loud inside the cab.
Old Oct 27, 2009 | 08:08 PM
RamWheelsBy4's Avatar
I have a 6" single miter cut stack cab high. I have an Aero Turbine 5050XL between the down pipe and stack elbow. I also have one of the instack mufflers. It is still too LOUD in the cab most of the time. The instack muffler did tone it down a little at cruising speeds, but not much. It sounds fantastic outside, but can be very annoying in the cab at times.
Old Oct 28, 2009 | 01:36 AM
surfram's Avatar
Your truck sounds pretty awesome Ramwheels...
http://www.youtube.com/watch?v=f7sFBICTrdQ
Old Oct 28, 2009 | 08:06 PM
Thanks, like I said it sounds great from outside the cab. Cruising speed is not to bad, but in town it is annoying a lot of the time in the cab.
mike moore
Nov 8, 2009 08:20 PM
coobie
May 8, 2008 05:34 PM
coobie
Apr 2, 2008 01:50 PM
crabman
Jun 2, 2003 06:21 PM
