Module
Module
Who make the best module, EDGE, QUAD, Diablo ect...... I really don't want the injector noise or the high pressure that some of them produce. I am looking for an adjustable box with level in the 30, 60, 100 HP range.
Thanks for the help.
using the thoughts that you are looking for, I would go for the edge,, fully adjustable on the fly (with the attitude) comes with guages etc. If you want a good downloader go with the diablo predator
kevin
kevin
No I am done with the downloaders, I just sent back my Power Pup today. I installed it and my truck would not start for 12 hrs
depending on how you mount the attitude it isnt hard to remove. But that is the downfall to all boxes, they leave visable traces.... whereas most programers leave little trace... But going by what you are looking for I would still go with the juice and attitude.
Kevin
Kevin
Does the Juice produce injector noise? Are there other ways of mounting the Attitude or do I need the A-Pillar mount? Sorry for all the questions but I do not want to buy the wrong product again
I have never had injector noise ever, the attitude comes with a L bracket that you can mount where ever you would like, or you can buy several different mounts for it, such as a A pillar or over the mirror, or in the dash under the heater controls, where you mount it is totally up to you
Kevin
Kevin
Kevin
Kevin
Thanks for the help!!
Check Out The Juice 2 Make Sure That It's Not Pressure On The High Level.even If So, I Would Not B Scared Of The Pressure.it's Not So Much The Pressure That's Bad, It's The Contaminants In The Fuel.it's Like Sandblasting Your Parts, Of Coarse Higher Pressure Will Come N 2 Play W/contaminants Faster Than Low Pressure.i've Seen Stockers W/bad Injectors On Low Milage Trucks.just My $.02
Amish hauler
Nov 6, 2002 05:19 PM
