Modified camshaft sensor?
Old Sep 17, 2005 | 08:54 AM
  #286
MikeyB's Avatar
gatf4,
Good report on the 6 degrees mod.
Here's some good info on timing. http://dodgeram.org/tech/dsl/FAQ/timing.htm
MikeyB
Old Sep 17, 2005 | 08:56 AM
  #287
MikeyB's Avatar
Originally Posted by hardyhindle
Has anyone thought of a name for this mod for our signatures yet?? I think it deserves one. I've been driving with it for over a week and I can't seem to empty my tank to calc my new mileage. I think tomorrow I'm gonna take a few more thou out of the hole after reading that last post... Don't know if I'm brave enough for 6degs though.....
Hmmm. How about Redneck Timing Mod (RTM) or Do It Yourself Timing Mod (DIYTM).
MikeyB
Old Sep 17, 2005 | 11:15 AM
  #288
SoCal-305's Avatar
Interesting article MikeyB about timing even if it doesn't directly apply to our year of engines. It seems the concensus is to have the timing set in the 14-15 degrees BTC range.
Does anyone know of the stock static timing setting for our 3rd gen HPCR Cummins?
FYI - I've had my tone wheel mod set at a 4 degrees advance for about a month now, and I think it's all good......
Old Sep 17, 2005 | 03:16 PM
  #289
hardyhindle's Avatar
Did you have to grind into the bolt holes also in order to hit four degrees??
Old Sep 17, 2005 | 04:45 PM
  #290
SoCal-305's Avatar
Yes, check out my prior posts in this regard......
Old Sep 17, 2005 | 07:29 PM
  #291
Originally Posted by caltom
I can't stand it... it's right out there in the driveway... knowbody would know... it'll just take a minute.... ahhhhhhhh!!!!
I have to wait till tomorrow before I can try 4 degrees.. The wife won't be home.. She cringes everytime I walk up to a 1 year old $50k truck with a wrench in my hands.... What she doesn't know...................
Old Sep 17, 2005 | 10:44 PM
  #292
gatf4's Avatar
My wife thinks I'm just like Tim Taylor (Allen) on home improvement . If a little is good than a lot must be way better I vote for the RTM.
Old Sep 18, 2005 | 11:29 AM
  #293
gus's 03's Avatar
Originally Posted by T1h5 Ta3
yep.. this tank i dont think ill do as well, ive played a little more but it looks like i ought to hit about 675ish.....
actualy i have to run over the pass this weekend, i used to average about 19.3 on runs over the pas, ill top her off and report back next week..
im back from my trip over the hill , ran 70-80 the entire way, im curently @ 692 miles for the tank and the overheads saying 43 miles till empty! injectors must be cleaning up!
Old Sep 21, 2005 | 07:04 PM
  #294
MikeyB's Avatar
The increase in fuel economy is for real. I filled up today and checked the mileage. The economy for around town driving is right at 20mpg. Twice in a row now!
MikeyB
Old Sep 21, 2005 | 09:03 PM
  #295
Dynocon's Avatar
MikeyB
How far did you change the timing?
Old Sep 21, 2005 | 11:02 PM
  #296
Superduty's Avatar
I'm seeing excellent fuel economy too. I can't give a before/after comparison because my engine only has a little over 3,000 miles on it, over half towing our 5er.
I'm seeing 13+ MPG pulling the 5er in my gallery. Combination weight is 16,500.
I'm seeing 20 MPG city driving if I'm gentle with it.
Pinch me, I think I'm dreaming.
Old Sep 22, 2005 | 06:08 AM
  #297
T & T's Avatar
I've advanced my timing until it pings at idle when the auto is in gear.
One of the things that I am noticing is it stumbles when idling cold, and lots more smoke until you really heat it up. The reason has to be the catalytic converter. Anyone else notice this?
Old Sep 22, 2005 | 06:12 AM
  #298
MikeyB's Avatar
I'm using the Rokktech crankshaft sensor which is only 2 degrees.
MikeyB
Old Sep 22, 2005 | 06:18 AM
  #299
MikeyB's Avatar
How far did you move the tone wheel? Sounds like you went a little too far on the timing.
MikeyB
Old Sep 22, 2005 | 09:35 AM
  #300
fjfonda's Avatar
I installed my Rokktech offset sensor last night and noticed the following this AM in my commute to work:
- Cold performance was pretty much the same (52 degrees this am)
- Once warm, the SOP throttle response is much improved
- The boost at full throttle (in 1st and 2nd on 48RE) seems to fluctuate a lot more. Previously it would peak at 32 psi then drop to 25-26 psi and return to 28 or so and lock in. Now it peaks about the same but swings back and forth a few times before settling in.
- I forgot about the mod a few times and was pleasantly suprised when accelerating from a stop.
- Engine noise is about the same but at 28,000 miles, I have the cam gear noise which would mask most noticable noise changes at idle. At cruising speed I could not notice any difference.
Disclaimer: I mostly tow with this truck and drive it minimally on my commute. Although I did commute in it earlier in the week, I may no be as "in tune" to unloaded performance changes as others are. I plan on towing soon and will update my oservations when I return.
Next step: Loosen the tone wheel and move it to the most advanced side of the "slop".
