Modified camshaft sensor?
Old Aug 28, 2005 | 02:24 PM
  #226
BlueDually's Avatar
I adjusted mine about a 1/16 of an inch, in the key slot. As said before it idles better, and more bottom end. Boost level at about 67mph went from 9-10 area to 6-7psi so its probably 2mpg better
with the TST it seems to smoke black a little more on 1-0, and more consistent power, put it on 3-3 and is incredibly smooth now, way more coal out the pipe.
probably the best thing I have done to the truck for the $
Old Aug 28, 2005 | 02:32 PM
  #227
MedicShawn's Avatar
I ordered a sensor from Rokktech on Friday hopefully I will get the same results.
Old Aug 29, 2005 | 09:41 AM
  #228
B1 Power Wagon's Avatar
I didn't really see any mileage improovements...but then again, I've been REALLY running it hard since I installed the sensor ....so maybe I did see a gain
Only time will tell. I'm going to adjust the tone ring today if I get a chance, just take teh slop out of it, not notch it. We'll see if that gives me any more.
I know this thing didn't really gain me any REAL power, but I am enjoying it thoroughly. I can see how some folks can get caught up in BOMBing now
Old Aug 29, 2005 | 07:17 PM
  #229
rammtuff's Avatar
I slotted my tone ring yesterday. Didn't really find any difference. Starts the same, same rough idle it has had for the last year, don't know if the power is any different or not. I filled up tonight so will see in a couple of days when I need to fill up again. This truck has always had great fuel mileage so maybe mine was one that was more advanced right from the factory. Modification took all of 10 minutes to do.
Old Aug 30, 2005 | 07:41 PM
  #230
HaulinBut's Avatar
Thanks to the help offered on this great thread, I just modded my ring. Couldn't have gone any better. I own a race shop and am a oldtime machinist, so I set it up on the Bridgeport and widened the dowel slot .040. Can't varify much about aircondition, less smoke, or power increase yet, but I DO believe I am seeing the following: noticably less boost needed to maintain a constant speed (on the order of only 2 or 3 #s at a steady 60mph). I filled and reset my overhead, left the Ramifier completely off, and was seeing much higher numbers than I am used to seeing on the return from the pump. It is only 8 miles, but I know what I usually see, and the numbers were improved enough to keep me from saying for fear that someone will think I am making a claim. I wish I had done this 1/2 way thru the 3697 mile trip I had just made! I will be making a 150 mile trip this weekend to watch some races, and that will give me a hint, but I am itching to do another longmiler.
One of my wishs is that the EGTs drop as a few have claimed. I learned on that trip that the altitude plays a major role in raising the temps with the box cranked in under heavy throttle. Near sealevel....no problem, high altitude....BIG problem.
I have hoped there would be something that could be done to help with the late cycle injection shot on this 04.5, and it makes sense that this might just do it.
I saw the sensor mentioned, but I am glad I did this, and thankful for all the imput. I will try to post whatever observations I have as the miles build.
Lusting for 20+ mpg!
Old Aug 31, 2005 | 07:31 AM
  #231
MikeyB's Avatar
Rammtuff,
Please fill out your sig so we know what kind of truck you own.
Took 10 minutes to R&R your tone wheel!!??
MikeyB
Old Aug 31, 2005 | 09:07 AM
  #232
Maccandy's Avatar
I'm reading all good thing about advance timing. Any down side to this mod?
Old Aug 31, 2005 | 11:57 AM
  #233
MikeyB's Avatar
Only downside is slightly more noise. But not as loud compared to the older 12/24v engines.
MikeyB
Old Aug 31, 2005 | 12:35 PM
  #234
rock's Avatar
I caught the bug and put a modified sensor in my truck. I lost at least 1 MPG I took it out last night and the overhead is creeping back to normal. It did even out the power band but used more fuel for me. I didn't notice a significant drop in EGT. I am starting to believe this mod is good for the 04.5 and up trucks and marginal at best for the 03 and 04.0. $80 down the toilet, anyone need a modified sensor?
Old Aug 31, 2005 | 12:44 PM
  #235
Doe_knob's Avatar
I to insatlled the sensor on my truck and noticed about a 1 mpg decrease on city driving
I will be going on a trip of 500 miles mostly hwy this weekend hope the mpg goes up. But the smoother power and responce is definitly nice.
Old Aug 31, 2005 | 12:50 PM
  #236
MikeyB's Avatar
Rock, Doe_knob,
Are y'all going by the trip computer for the fuel economy? From mine it appears the fuel economy is going down but looking at the odo and the fuel gauge I can tell my fuel economy is better.
MikeyB
Old Aug 31, 2005 | 03:25 PM
  #237
HaulinBut's Avatar
Maccandy,
As far as I can tell, the only downside is if you slip while deactivating the belt tensioner and flatten a finger between the balancer and the belt.....DOH!!
Old Aug 31, 2005 | 04:15 PM
  #238
rammtuff's Avatar
Originally posted by MikeyB
Rammtuff,
MikeyB
I filled out the sig.
Yeah it took 10 mins to do the tone wheel. Had to stop for a coffee at some point.
Doesn't take too long to lop out 4 bolts, 6 strokes of the file, and stick it back on.
Old Aug 31, 2005 | 04:42 PM
  #239
hognutz's Avatar
throw that b$tch on ebay. I just ordered one yesterday to play with. I looked there first. someone will buy it.
if you went by overhead you should hand calculate. try a tank each way with the same driving habits.
Old Aug 31, 2005 | 05:12 PM
  #240
MikeyB's Avatar
Which side of the dowel pin hole did you file? Should be the counter clockwise side if facing the engine from the front.
And how much material did you remove?
MikeyB
