Modifications, Am I missing anything?
Intake...Any plain jane torque tube with a good cone filter for diesels will be great ..... I use a 4 inch hole in my stock air box and it drops temps and improves air flow drastically. The K and N in my 04 works great and the intake pipe is cleannnn.
For exhaust just replace the muffler.....there is nothing worse than spending 500 on an exhaust and to look under the truck to see it all rusty ....and its stainless steel....I have a wicked short 4" muffler that cost me 70 that will flow better than most on the market.
The intake horn.....unless you are running way over stock boost ....this is a huge waste.
I'm not jamming on your statements Kerry... just added my opinion to them :-)
Everything on our trucks is good for at least 500hp as it sits. If you're not looking to spend a lot of mods.... opening up the intake for more air and opening up the exhaust will make a big difference. The problem is, it's hard to just stay on level #3 with the smarty. Because of that... a bigger turbo will help keep the EGT's down a bit.
Do you mean I can go up to about 500HP with all the equipment presently on the truck, without changing anything? I'll still add guages to monitor stuff, of course. Which turbo would you get?
After reading through this wealth of knowledge we have here this is the revised plan:
Intake:
Ok, I'll do the stock intake torque tube modification, (Baffle removal) Install a True Flow filter element in the stock box, and cut a 4" hole in it. Someone recommended some 1/2" screen over the hole, should I do that?
Guages:
The resemblance to factory is why I was wanting to go with Isspro. Up until now, I haven't heard anything bad about them. I still plan on them, Should I worry?
Intake Horn:
I'll delete the CFM for now and go with kuhkuhkyle's suggestion of using a Boost Bolt.
Exhaust:
I live in Az, so rust isn't much of a problem. I'll could take Morse's advice on the exhaust and go with the Walker 4'' straight through (model 21471), or abc4yew's advice and go with the 4" short nelson muffler. More research is in order.
Tranny:
I'll go with rustyshakelford's advice on putting the tranny probe in the hot line.
Programmer:
Smarty
Long term:
5" cat back MBRP, Torque converter and Valve body, New Turbo... abc4yew mentioned the 62/14. Need more info on that...
Please continue to feel free to chime in and let me know what you think.
Ramified5.9
46
Nov 26, 2008 08:09 PM
diesel_kid
Mar 30, 2008 05:56 PM
Elohim1
Mar 29, 2008 02:28 PM
bansh-eman
19
Jan 18, 2008 11:00 PM
