mini packs
Washboard
I wonder if the mini packs would help with washboarding dirt roads? My truck likes to make washboard roads, I end up running around in 4x4 on dirt roads and turn roads just to keep the roads smoother.
They are a good start, but you could get addicted. Also don't forget a proper valved shock.
depends haw they are valved and what they are intended for. I am not sure.
Typically when dual shocks are used, they are set softer than a single shock from the same source. Many times they are used to get more piston area and more cooling instead of going to a RR shock with a larger piston.
So going to one could be way to soft conceivably.
If they are two shocks that are used in a single application typically, then yes I think they could. Basically just the two are better than 1 theory with out changing valving.
This is one reason I went with a re valve-able shock. I can change it out to my liking when I want and they should last "forever", LOL
So I guess I don't know for your particular application.
I am going with a set my self on my 2nd gen from Carli real soon.
Bob
The mini packs should help you here. I will say it depends on how fast and how bumpy the roads are. The full leafs allow for more articulation than stock and mini packs. Soaking up more bumps and stuff for a smoother ride....
A Friend of mine down in San Diego pulled his firestones off and added these,he was amazed at the improvement.BajaBob you out there?
Bob
those do look like a cool air bag setup. I just done tow that much to warrant them.
As for the off road ride, I also adjust my air pressure in the tires if I am going to be dong allot of off road driving. That can help out with the ride. Like Bob said, dump the air out of the air bags, only needed for towing. That will definitely make the ride worse.
hotrod929
Dec 9, 2009 04:39 PM
West Coast
Mar 3, 2009 09:25 PM
silkywoods
17
Feb 15, 2008 09:00 PM
clayne100
Nov 3, 2006 12:36 PM
April-May.....full boat, 3.0's, bags, bumps, Walkers and glass all the way around....
