mini packs
here is a pic of them installed. I could not find a before picture.
The hardest part can be the drivers side. The Emergency brake cable can get in the way. It can be removed with fuel line removal tool to take it off. Other than that, it is a tight squeeze.
they were good, but these are better. LOL
They (the mini) did help with the expansion joints and the initial hit from big bumps. The stock overload just hit to soon for me.
With the full replacements, the springs just flex and articulate more and ride smoother.
more info on my leafs can be found here
http://www.lorenzindustries.com/products_leafs.html
I am even quoted in the write up.
Whatever you say "MR GARCIA"
Ok, now that that's out of the way, if you REALLY can't figure out what the difference is between a set of custom dual purpose leafs and some firestone air bags, I think you need to do some research.
Scott
Ok, now that that's out of the way, if you REALLY can't figure out what the difference is between a set of custom dual purpose leafs and some firestone air bags, I think you need to do some research.Scott
