Longview Tx shops?
Longview Tx shops?
Hey there gang,
Anybody know of a quality shop in the Longview, Tx area?
I am looking for some basic maintenance work (valve train adjust) and some head studs (and possibly fire rings).
Suggestions?
Thanks!
Suggestions?
Thanks!
I cant help you on a shop in Longview. Is this work for the truck in your sig? If so the fire ringing is not needed nor is the headstuds at the level you're currently at. Factory head bolts will hold fine up to 45-50lbs of boost.Headstuds have held 80lbs of boost with the MLS headgaskets that are on CR's. If the need ever comes for more than that you will want to o-ring the head. Fire ringing is more for competition use and not recommended for daily driving.
I may know somebody. He works another job during the week.... but he works on autos/pickups on his days off. He's got a shop out near Hallsville.
did you try the shop out by the gregg county airport? i can't remember the name . i think it is kahoonas mechanical. i am not sure on the name . i know they work on a lot of diesels. why not do the work yourself ? i have done all of my work on my truck . i just got done with changing out my heater core.it was not all that easy.what i am saying is, you gotta start some where. good luck on whatever you do.
I will definitely do the twins myself too
Duck Hunter
Dec 6, 2003 01:29 PM
binford4444
Nov 26, 2003 03:50 PM
