lift the back seat for stereo
Old Aug 14, 2005 | 01:37 PM
Nvisable's Avatar
I need to lift the back seat of the truck about an inch to add some amps. I'm worried that there isn't enought room for proper cooling from the top of the heat sinks to the bottom of the seat. I've also considered fans, but I don't want the fan noise.
Is it as simple as adding a spacer blocks and getting four longer bolts? When I lift the seat bottom how does the seat back slide up and down with the seat?
Thanks.
Old Aug 14, 2005 | 07:02 PM
BigBlue's Avatar
That's how I lifted mine. I took 2 pieces of 2" angle iron and welded them together. Drilled a couple of holes and screwed it down. I also had to make longer brakcets on the back of the seat. In the pic you can just barely see the edge of the angle iron. My seats lifted 4".
Old Aug 14, 2005 | 09:01 PM
DSLRammin's Avatar
Jacking the bottom is not big deal but the backs of the seats have a hook that slides over a small bar. (see my pics under sound deadening) I don't remember how long the hook is but as soon as you go to far the back of the seat has nothing to hook in too.
Old Aug 15, 2005 | 05:16 PM
genros's Avatar
I have two jl audio 12"s from my last truck. Has anyone put them in under the back seat. Although I like the install in the post above i aim for stock appearence. Id like to face them up under the seat. Any thoughts?
Old Aug 15, 2005 | 06:47 PM
Nvisable's Avatar
Wow, 4 inches. I'm only going for 1 inch lift. So I guess it's doable.
As for the two JL 12 inchers, the magnet and basket may not fit into the holes on either side of the cab. The other thing about JL's would be the cubic size needed for the sub. My last JL sub wanted 1.5 cubic feet.
Old Aug 15, 2005 | 10:30 PM
deviousracing's Avatar
i have a 10in in my truck without doing anything to the seat, just got an underset box, you dont need big *** speakers anyway, youll just go deaf. Mine sounds really good.
Old Aug 15, 2005 | 10:44 PM
Badd Dogg Guy19's Avatar
"Devious", what speaker box do you have. Is it the one that goes in the under seat storage in the back?? If so, is it in the pass. side, or driver side? I was thinking of getting the drivers side box, Im not looking for brain ratteling bass, just something that will give a nice thump when needed. I thought maybe the drivers side well was a little to small. Just wondering what you might have, Thanks.... Dog
gts95
Mar 25, 2009 11:09 AM
Common
Jul 27, 2006 09:46 AM
bigsam
Aug 20, 2005 09:29 PM
JoshPeters
Apr 3, 2005 08:13 AM
Lightman
19
Dec 23, 2003 02:36 PM
