Can you fit a stereo amp behind the rear seat ?
Old Dec 10, 2003 | 07:45 PM
Lightman's Avatar
I hear of a lot of earlier gen cummins mounting amps on the wall behind the rear seat. Is this possible with a 3rd gen? It seems pretty tight back there, but its possible that it tapers forward toward the front of the truck on the bottom. Hard to see. If anyone has any interesting amp mount location ideas for 03's, please throw em forward! Thanks!
Old Dec 10, 2003 | 07:59 PM
quantrill88's Avatar
Re:Can you fit a stereo amp behind the rear seat ?
hmm, interesting idea, never thought bout that for my 2nd gen. only concern would be how tight a fit is it? would there me enough ventilation for the fans?
its not for everyone but i removed my backseat and mounted the amp in between 2 sub boxes. if u look at bigblue's stuff on page 3 of the photos section its exactly like that
good luck, im sure some of the stereo gurus like sean and jamie will give u some good advice too
Old Dec 17, 2003 | 01:31 AM
Scotty's Avatar
Top's Younger Twin
I am going to move my amps under the front seats...currently under the rear.
I am making a custom box under floor for my 12W7 to plumb into the area on the left side rear cubby hole. ;D
JL 300/4 is next to go with the Rockford 800 and the other amp.
huh?
I won't put amps behind the seat...cannot adjust them plus the seat bottom cannot be flipped up since the amps take up the space where the seat retracts against the cab wall. At least they did on my 01.
Scotty
Old Dec 17, 2003 | 07:45 AM
trailblazenyj's Avatar
I put my amp on the hump between the two rear cubby holes. I don't have the shelf under the rear seat so that may not work for all. I was able to fit the crossovers behind the back seat but they were pretty small.
CD changer and cobra remote cb went under drivers seat.
Old Dec 17, 2003 | 09:39 AM
Lightman's Avatar
how are you guys finding room iunder the front seats with all that power seat apparatus?
Old Dec 17, 2003 | 10:04 AM
RamDan03's Avatar
[quote author=Lightman link=board=49;threadid=23558;start=0#msg225064 date=1071675552]
[/quote]
Not to mention the factory jack is under the front passenger seat. I'm not sure where they are finding room. If they are, it is definitely a tight fit, or the amp is very small.
Old Dec 17, 2003 | 10:23 AM
Lightman's Avatar
Well I got such a good deal on a two week old JL audio stealthbox on ebay, it fits right under the back seat on the passenger side. Seat stays there etc, and it fits perfectly in that underseat storage. I have an amp left over from the JL stealth box in my last vehicle(they sound great), so I figured why let the amp go to waste, might as well get the stealth box and use the amp... Well this amp mounting is proving trickier than I thought ;D Half inclined to sell the stealthbox and say forget it, but they do sound so good!
Scotty how do you plan on fitting anything under that seat bigger than a tiny amp?
Old Dec 17, 2003 | 10:33 AM
AMERICANPIE's Avatar
I mounted a JL Audio 500/5 behind the seat (had to remove one of the vents) a JL Audio stealthbox and new speakers and cd player. incredible sound in my 04.
Old Dec 17, 2003 | 11:01 AM
cquestad's Avatar
I have a dual 10" sealed enclosure under the rear seat from Moose Audio. (2) Infinity Reference 10's dvc powered by 450x1 RMS amp under driver's seat. 6 inch Infinity Reference in all doors with 65x4 RMS amp and capaciter under Passenger seat. I had to remove the jack and put it in the tool box...
I have built many stereos in the past...and this has to be one of the sweetest sounding, best looking/fitting ever...
2004 Quad HO
Old Dec 17, 2003 | 08:11 PM
lawnman757's Avatar
I put a 10" kicker sub under the rear passenger seat in a Q-logic box and mounted 2 kicker amps under the driverside rear seat by cutting a board to cover the factory storage area.
Old Dec 18, 2003 | 09:09 AM
my sub amp is under the center console. I do not have the hidden storage area so I may have more room than the fancy trucks
Old Dec 18, 2003 | 03:05 PM
mehaffydr's Avatar
I have one amp (alpine) under front passanger seat one amp(JL) under driver seat, 6 disc changer and navigation dvd under and behind rear seat. My amps are rather large but have no problem under seats. I put my jack and tools in tool box,
Old Dec 21, 2003 | 04:28 AM
bellyscraper's Avatar
Did'nt anybody order the 6 cd changer with the infinity speakers from the factory?.
